TR2/3/3A paint tight spots
sp53
I got the other half blasted and primed. I basically used paint remover in the areas of no rust and the rusted and tight areas I sand blasted then went over the surface with the sand blaster. My blaster is not strong enough to take paint fall off all day long. The compressor starts to fad after a few minutes. Anyway, my question is should I put color on those hard to get spots now or weld the floors in and put the color on then. I recently got a small cup for the paint gun so getting in might be easier. When I look the welds and how they got paint up in those hard to get at places, I gain more respect for those craftsman in the day.
Brinkerhoff
You are approaching this with much more thoroughness than the "craftsmen" who painted it in the day ! They just blew enough color on the cars to call them red or white , and anything on the insides was barely more than "overspray". You'll be fine.
Thats the reason thet rust as bad as they do. If the "craftsmen" put a thick coat of paint underneath and over places we wouldn't be replacing so much metal today.
marv
Jerry
Yea, I have to admit that some of my spare tire slot is painted with a brush. My gun would not fit in there. But then, I have never used the spare in a TR3.
Jerry
dklawson
For tight spots I go even smaller than a touch-up gun. I use a siphon feed, cheap air brush (like a Badger model 250). Without much effort you can reach into tight spots and get primer and/or color on difficult areas with minimal overspray. If there are areas that really will NEVER be seen, and they can be reached with a paint brush... I am not above getting primer and paint into the nooks and crannies using a disposable chip (or even acid) brush.
TomMull
marv
Not only Triumph, of course. The original paint on the metal dash of my 73 Buick Apollo fades from Green top coat to gray primer just as it curls out of sight above your knees. Tom
trrdster2000
Does your gun nosel adjust. I go with a needle spray for all the corners and seams. It will go a couple of feet with no problem. Just keep the pressure down on the trigger, then open up the nosel to a couple of inches until you can get to were a normal fan will work. This way you are really forcing paint into the crevasses for protection, if you get a run in these areaers and it gives you pain, wipe it off with the back of your hand and back off and spray it real quick, it will flow together. We are talking about places only you are going to see for the next 50 years, if you are lucky.
Wayne
LarryK
I have used an air brush for small places and engine compartments, dashes and boots.
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
D TR6 Valve cover paint Triumph 5
TomMull Paint over galvanized parts? Restoration & Tools 8
Sopwith_Camel MGB-GT lick of paint 1 2 3 MG 2
Rut MGB Pale Primrose touch up paint MG 4
J Paint code Spridgets 0
J 1960 Bugeye Paint Codes Austin Healey 1
J Paint code Austin Healey 4
M Old English White Paint Code for early BE Spridgets 1
J Flaking Paint Inside Differential Austin Healey 6
C Under boot and under bonnet paint? Austin Healey 7
T TR2/3/3A Chassis paint color Triumph 10
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
vette MGB Paint Code MG 8
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
B Engine paint Austin Healey 17
D Lotus Elan S4..Bodywork evaluation..Strip & Paint? Lotus 10
P TR2/3/3A Chassis paint questions Triumph 8
B Carnauba wax Vs. new ceramic paint sealants Austin Healey 35
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
