Paint over galvanized parts?
TomMull
I posted a more car specific question on the lotus forum but in general, does one gain anything by painting galvanized steel parts?
Tom
LarryK
Biggest problem is getting it to stick.
TomMull
TomMull
It would appear from what I can find that it it difficult but not impossible to get it to stick. But does one gain anything? That part will be hidden so will not be seen until the next owner replaces it so I'm interested only in corrosion resistance. (I took more than half of the original part out of the car with my shop vac.)
Jim_Stevens
I soak parts in POR15 Metal Ready prep solution and that seems to have worked.
TomMull
TomMull
That's what the literature says so maybe I'll give it a try although I've never been a fan of POR15
Popeye
Bronze
Dumb question: how are cars with galvanized sheet metal painted?
...found the answer here: https://grassrootsmotorsports.com/forum/off-topic-discussion/painting-galvanized-steel/71891/page1/
Javelin posts, "Ooh, ooh, ask the guy that sells steel for a living!!!
:D
It depends on the galvanizing. Standard galvanized (with "spangle") is coated with zinc in a "hot dip" process. This is a thick coating that leaves a satin, greyish surface. Electrogalv is the same coating, only applied differently, and much, much thinner. This is typically "brighter" and reflective. Neither is suitable for painting whatsoever. Not only will paint not stick to the coating, but sanding the coating is hazardous and you might as well just use regular old hot roll steel (mild steel) if you do that.
Now, Galvalume (or Algalume) is galvanization with 55% aluminum and 45% zinc. Galvalume is much better suited to painting and corrosion resistance. As a bonus, it has some heat-resistant qualities. This is fairly easy to find and only slightly more expensive than regular galvanization.
Lastly is Galvannealed or "Satin Coat". This is a regular hot-dip galvanized 9all zinc) that's immediately heat treated (annealed), which alloys the steel with the zinc. The finish has no spangle and is a dull matte grey finish. This is the galvanization that car manufacturers use. You can weld it and paint it with no ill effects whatsoever. It is also extremely durable, being an actual alloy. This is more expensive, but well worth the money.
Evan: try finding a local to you metal sales place, either a supplier (like what I work for) or a sheetmetal shop. You should be able to buy Galvalume all the way down to 30 gauge (it's very common in the steel siding/roofing industry) and Galvannealed down to 22 gauge.
Hope that helps!"
Now I know!
TomMull
TomMull
My sills are hot dip galvanize unlike car sheet metal. Still might try the POR15. I can't see that it will do any harm. Tom
Popeye
Bronze
Advice from the Grassroots forum is dipping in muriatic acid to strip the galvanizing. Outside for health and safety reasons. A sill is pretty big, though...
Milliecat
Hi,
I used to work for a HGV trailer manufacure , and we produced a lot of galvanised and then painted parts and trailers - the galv bits are first given a Mordant solution to clean and etch before paint , see below
Ivan
[h=1]Rustbuster T-Wash Mordant Solution for the Treatment of New Galvanised Surfaces Prior to Painting[/h]
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
D TR6 Valve cover paint Triumph 5
Sopwith_Camel MGB-GT lick of paint 1 2 3 MG 2
Rut MGB Pale Primrose touch up paint MG 4
J Paint code Spridgets 0
J 1960 Bugeye Paint Codes Austin Healey 1
J Paint code Austin Healey 4
M Old English White Paint Code for early BE Spridgets 1
J Flaking Paint Inside Differential Austin Healey 6
C Under boot and under bonnet paint? Austin Healey 7
T TR2/3/3A Chassis paint color Triumph 10
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
vette MGB Paint Code MG 8
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
B Engine paint Austin Healey 17
D Lotus Elan S4..Bodywork evaluation..Strip & Paint? Lotus 10
P TR2/3/3A Chassis paint questions Triumph 8
B Carnauba wax Vs. new ceramic paint sealants Austin Healey 35
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
D BT7 top/paint protection Austin Healey 5
