Paint lifting
warwick-steve
Any paint experts out there?
My BT7 was painted with 2 pack about 8 years ago to a pretty high standard. It remains unmarked, however, I have noticed a small area where the paint seems to have lifted.
There is an area about 2in by 1/2 in in the crease under one of the tonneau fitting studs at the rear which seems to have lifted slightly. It is hardly noticeable however I do not want it to get larger. It may have been like this for some years and I only noticed it when I removed the tonneau which has been on the car since I bought it two years ago.
Should I just leave it or should I put a pin hole in it so when the body gets hot it does not cause the area under the paint to expand?
Any advice appreciated
cheers
Steve
Ugh. I'm not a 'paint expert,' but I've done a fair share of auto painting. What usually lifts paint is rust (sorry). Clear coat can peel off if, for example, the clear was shot after the base coat had too much time to cure. Flaking, fisheye and orange peel have other causes.
John Turney
It sounds like the lifting area is on the rear shroud, which would be aluminum. It may be because the primer used may not be suitable for aluminum. I would think putting a pinhole in it would allow water to seep in and worsen the problem.
Healey Nut
Pictures speak a thousand words . Is it just one blister or a bubbling lumpy section .
If its just one blister it could be a section of paint where there was contamination of the primer and the paint hasnt bonded to the primer . If its multiple small blisters or bubbles in a patch then thats probably some form of corrosion .
Post a pic and you probably get a lot more input .
warwick-steve
warwick-steve
Thanks for your comments
It is one blister.
I found photograph of the area as it was 2 years ago and the blister has almost doubled in size lengthways since then. It is in the concave crease under the tonneau fixing stud and not very noticeable however I am concerned about it getting bigger. I am not sure if a paint shop can do a localised repair on a two pack surface,
I will monitor the blister and contact a body repair shop with a good reputation for paint jobs and get their advice.
Thanks again
Steve
Just curious, what is a 'two pack' paint job? Here in the Colonies, you have one- and two-stage jobs; the former is (usually) catalyzed--lacquer excepted--the latter being a base/clear (I think).
Healey Nut
Two pack paint is where the paint (colour ) has an activator added to activate the hardening . Without it the paint would never set fully . You use the two pack paint then clear on top if desired .
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
D TR6 Valve cover paint Triumph 5
TomMull Paint over galvanized parts? Restoration & Tools 8
Sopwith_Camel MGB-GT lick of paint 1 2 3 MG 2
Rut MGB Pale Primrose touch up paint MG 4
J Paint code Spridgets 0
J 1960 Bugeye Paint Codes Austin Healey 1
J Paint code Austin Healey 4
M Old English White Paint Code for early BE Spridgets 1
J Flaking Paint Inside Differential Austin Healey 6
C Under boot and under bonnet paint? Austin Healey 7
T TR2/3/3A Chassis paint color Triumph 10
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
vette MGB Paint Code MG 8
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
B Engine paint Austin Healey 17
D Lotus Elan S4..Bodywork evaluation..Strip & Paint? Lotus 10
P TR2/3/3A Chassis paint questions Triumph 8
B Carnauba wax Vs. new ceramic paint sealants Austin Healey 35
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
