tahoe healey said:
It would be necessary to remove the fenders to get the beading out.
I got a quote of $3500 from one and $15,000 form another.
Roger, you have seen my car. It aint that bad. Its a beautiful driver. I just want to get rid of the chips and paint flaws.
Hello TH,
Actually you don't have to remove the fenders to get the beading out. You loosen all the bolts, pull the fender away from the cowl a bit, bend the beading tabs to straight then pull the beading up.
A cheap paint job will leave the bead and mask it. Not good. The paint should wrap around the top edge of the fenders and the aluminum cowl. Ask any good bodyshop about what happens when you mask. Down the road, with vibration and flexing, that masked area will start peeling or cracking because of the hard stop line.
I'm just sharing with you what I have learned about what it takes to do the job right. Body shops use my service and I have learned a lot about what it takes to paint a car.
Consider this. The bodyshops that use me, tell me a full paint job for a modern car costs about $5,000 now. (They R&R all the trim). Miracle will paint it for what, $500?
You can save a lot of money by taking the car apart and going to the local hardware store and getting some paint stripper. Deliver them the stripped car and let them do their magic. You should be able to get your car back in a couple weeks and for a price you'd be happy with.
I recommend you strip the car to metal so there are no surprises. Ask any good bodyshop what they think or ask the guys here on this forum what they think.
I'm attaching a photo of one of my wings. Check out the number and the sizes of the holes that were under the bondo. Many areas of my car had hidden damage/repairs like that. I would never have known about them if I didn't strip the car down.
Yes I have seen your car, I voted for you! You have a beautiful driver.
Just be careful of taking the band-aid approach to fixing your concern. Just want to get rid of chips and paint flaws. Sounds like you think a quick masking of the beads, block and sand and shoot a couple coats of paint will make you happy. Maybe it will.
Maybe that's the way it's been done by all the PO's. Maybe that's why your paint is chipping and has the flaws? Maybe under your paint, your car looks like mine did.
Good luck with what ever you do.
Cheers,
Roger
