Pacesetter Header
smokenbutch
Has anyone put a pacesetter header on thier Midget (1500) and if so how hard was it? Did you hookup to your stock exhaust? I am looking into buying one.
Thanks
JPSmit
I am also interested.
I seem to recall that some folk weren't pleased with the fit of the pacesetter, but, I have no direct experience.
I'm curious about this one also
https://tinyurl.com/ygpddcs
aeronca65t
I put a Pacesetter on my 1500 some years back.
The fit was terrible and I would have sent it back, but I was short on time (race coming up). So I cut it up and re-welded it.
Poor quality in my view.
I had a pacesetter on my 1500, and i installed one on a B this spring. I do not care for them. they both required machining of the sealing surface by a fair amount as they were horrible. And some tweaking of the bends to get them to fit good. When mounted on the B the outlet was pointed at the drivers headrest!
For my car i ended up scrapping the pacesetter and going with the 4-2-1 from APT https://www.aptfast.com/
That one on ebay looks pretty good and the price looks reasonable...
m
Legal Bill
It was this way going back to the 1970s. The Pacesetter stuff was cheap and aweful. APT and Seven had good headers. I'm not sure if Seven is still around any longer.
bugimike
I also had issues with a Pacesetter for the 1275! Fit was terrible...much modifying to make it fit right!
jvandyke
I've got a Pacesetter on my 1098 and it doesn't fit very well. It's flanges are not the same thickness as the intake and since they share the same hold down bolts...that's a problem. I couldn't bring myself to grind down the intake to match a crappy exhaust. I think I might be better off getting on original exhaust manifold. I can't believe there's much if any difference in performance between the two.
bugimike
That flange problem was the same one I had! I do think there is a noticeable difference between the stock unit and the header though (and certainly some weight-saving too!).
jvandyke
Yeah? You think it's worth it? Last time I had it apart I made some shims to add thickness to the Pacesetter flange. I still don't think it seals well. I've blown out the manifold gasket a few times already. Maybe I'll make that a winter thing, to make the Pacesetter fit. I was going to Vizardize the stock intake anyway.
Dadandson
I installed a Pacesetter on my 1275. I found the header flange thicker than the intake. I machined washers with a step to correct. About 1/16" if I remember correctly. Other than that, it fit just fine.
johnrip Wedge TR7 pacesetter header connection to stock exhaust Triumph 2
eejay56 Pacesetter header plug Triumph 6
Mark Jones Pacesetter header - any good? Triumph 9
J pacesetter header? Triumph 11
Morris Pacesetter Header Spridgets 4
W Good price on Pacesetter Monza Muffler Spridgets 0
J Spitfire Pacesetter/Monza Exhaust on 69 Spit Triumph 12
A Dual SU carbs pacesetter exhaust MG 0
Brosky Pacesetter Headers Yes or No? Triumph 13
J has anyone used pacesetter headers and monza exhau Triumph 2
Morris Pacesetter Headers again Spridgets 1
K TR2/3/3A Using header wrap on a street car? Triumph 3
C LCB header with 1500 single carb inlet manifold Spridgets 1
K TR2/3/3A Intake header crossover passage..... Triumph 4
CARSINC Please Identify this Exhaust Header Spridgets 2
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
JFS TR2/3/3A Exhaust Header Fitment Triumph 13
P For Sale Weber carb/intake, header Spridgets Classified 2
J For Sale Header, hub caps Spridgets Classified 1
M Muffler Options with Exhaust Header Spridgets 1
bugedd Free header Spridgets 0
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
Rut TR4/4A Header seal attachment Triumph 0
Rut TR4/4A Header seal Triumph 3
R TR6 tr-6 header Triumph 0
B Advice on Wooden Header and Side Trim Rails for a BJ7 Convertible Top Austin Healey 9
D TR4/4A General header question Triumph 6
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
Joe Reed General Tech VHT Flame Proof Header Paint MG 17
tomshobby Header Rail Seal Spridgets 4
H TR4/4A Header Rail Assembly Triumph 2
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
Jim_Gruber Looking for header and rear BE Top bars Spridgets 18
N Recommend a header? Spridgets 4
D BJ7-8 header seal retainer Austin Healey 3
Boggsy64 MGB Three port exhaust header? MG 6
B TR6 TR6 decision on header/manifold/exhaust Triumph 4
V early BN4 question - top & header rail Austin Healey 3
B Header rail weatherstriping Austin Healey 6
G Long center branch header for 1500? Spridgets 0
L Tubular header to ss exhaust pipe Spridgets 12
Coyote1 TR6 TR6 Header Rail Question Triumph 4
JPSmit Header and muffler connected Spridgets 16
JPSmit Header Question Spridgets 2
GBRandy Wedge TR8 Header Install Triumph 42
bthompson Hood header rail gasket Spridgets 9
glemon Best Glue for Header Rail Triumph 8
7 Spitfire Spitfire Header Triumph 6
JPSmit Header Question Spridgets 9
tahoe healey header rail cover Austin Healey 0
