Optional rear seat for a Frogeye?
Frankenhealey
Anyone know much about these?
Cheers,
Ian
Biff
The optional rear (jump) seats began with the MK-II Sprites and MK-I midgets. I have one in my MK-II.
JPSmit
At bronte there was a BE with an original child's seat. Same as a regular bucket seat, less than half size sat between the seats - very cool.
Rik
Thanks for the compliment Kim. I made one for my 1500 after seeing an original one for sale on Ebay. I just had a kid ask me where the seat belts were for the back seat.
Rik
Frankenhealey
Frankenhealey
This from the guy selling it
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Have an unused from new (still in remarkedly good condition)optional rear seat in red with white pipeing.
Story from Father-in-law was that it was from a Frogeye Sprite he was selling from new and customer refused to pay extra for it, so it was taken out and was still in the loft when he died.
Failed to find anyone who is aware of this item fitted to the 'Frogeye' But although well into his eighties have never known him to be wrong on any details of old cars, so perhaps it was a 'special' or rarely used extra. Contact with A.H. Spares revealed a rear seat fitted to later models but not to the Fogeye.
The 'seat' is foam filled with a flap on either end of the front with a stud fitting, and a metal lined strip at the other edge presumably to fit into some sort of channel,presumably more cosmetic than an effective seat. [/QUOTE]
smaceng
Jack,
Here is a poor picture of what has been called the kid's seat?
Maybe this is an armrest?
HealeyRick
I can't imagine that's for a bugeye. If it is, it may be in the running with the Tornado fuel saver as the most useless auto accessory in history. Smaceng, that's not the child's seat, it's an aftermarket armrest. As JPS said, the child seat looks just like a regular bugeye bucket seat, but about 1/3 the size. It has u-shaped brackets on the bottom that fit over the rear of the transmission tunnel. The brackets could be bolted to the tunnel. Like the bugeye, there were no seat belts to keep the lad in place. Putting a kid in one today would have you arrested by Child Protective Services.
apbos
A picture can be seen in the google books preview of the Horler book Orginal Sprite. I'm glad our youngest is 11 and would never be able to fit in one. Link Original Sprite
jlaird
My oldest son set in one of those seats for three years in the mid 1960s.
That BE had the rear deck cut out like the later models. Came to me that way used.
MGTF1250Dave TR2/3/3A TR3 Optional Rear Seat Triumph 22
B Optional windscreen washer 1957 Triumph 8
JodyFKerr Tools & optional items Austin Healey 7
Brosky TR6 TR6 V-8 Automatic, with optional clutch pedal Triumph 9
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
