Oil pan Gasket
DNK
So all the gasket makers show this for a TR8
But that won't work as the front or back is more flat like this
I can't seem to find a gasket
Looks like I fill have to goop it on
Darrell_Walker
Maybe I'm a bit slow today (Maybe? she says...), but the two look the same to me (other than the one in the set looks a bit tweaked).
Brosky
It looks the same to me too and I don't drink, so I can't have twisted vision.
TomMull
Me too and I have a wee tot every day. They do get quite distorted in storage so I'd spend some time stretching it around to pan with a few bolts. The old cork gaskets were quite fragile but the synthetic ones can be tweaked quite a bit.
Tom
DNK
DNK
Compare the left corners
Top one has a bigger angle
Sheesh :devilgrin:
DNK
DNK
It's there , hasn't been punched you can see it right under the little logo
bigbadbluetr6 TR6 Oil pan gasket Triumph 2
Crankshaft Oil pan gasket seal Triumph 10
Morris Oil pan gasket Spridgets 10
Geo Hahn TR2/3/3A TR3/4 Oil Pan Gasket Triumph 49
4 '03 X-Type 2.5L Oil Pan Gasket R+R ? Jaguar 2
mountainman TR2/3/3A TR3 Oil Pan Gasket? Triumph 7
GBRandy Oil Pan Gasket Installation Triumph 11
boxfullofyertoys Oil Pan Gasket Spridgets 8
CinneaghTR Oil Pan Gasket Sealer? Triumph 14
roofman Spitfire Spitfire oil pan gasket question. Triumph 8
RedTR3 TR2/3/3A TR3 Oil Pan Gasket Triumph 9
A TR6 TR6 Oil Pan and head gasket leak??--help Triumph 4
L Does anyone use gasket sealer on the oil pan? Austin Healey 2
J Oil Pan Plug Gasket [New or Reuse?] Austin Healey 9
kyreb1862 Oil Pan Gasket Replacement MG 2
Russ Austin Oil pan gasket Triumph 5
M Oil Pan Gasket - 4 inch pieces? Austin Healey 2
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
M TR2/3/3A oil pan bolts Triumph 16
69MGC T-Series TC Oil Pan Weep Hole, Is it really necessary? MG 4
S 1275 oil pan removal Spridgets 30
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
I Bugeye oil pan help Spridgets 3
T Oil pan leak? Spridgets 7
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
D Oil Leak at rear of oil pan Spridgets 11
D TR2/3/3A '59 TR3A oil pan leak Triumph 12
T TR6 Oil pan Triumph 5
R GT6 Oil pan bridge installation Triumph 15
T TR2/3/3A TR3 Oil Pan Paint? Triumph 2
K TR2/3/3A Oil pan Again.... Triumph 4
K TR2/3/3A Oil Pan bolt torque spec? Triumph 2
germanmichel Camshaft change , oil pan has to be removed ? Austin Healey 2
bugedd Front suspension and oil pan Spridgets 17
Michael Oritt Leaking oil pan Racing 8
RJS General TR Straightening Oil Pan Triumph 5
D TR6 Tr6 oil pan Triumph 3
J Measurement for aluminum oil pan Austin Healey 3
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
T six cylinder oil pan - wtb Austin Healey 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
SMGoose Oil pan Triumph 9
T TR6 Will a 71 TR6 oil pan come off in the car? Triumph 3
R Alloy Oil Pan from Moss Austin Healey 9
M Leaky oil pan... again Triumph 16
I source for used 948 oil pan Spridgets 4
M Oil pan torque Triumph 23
T 1500 oil pan is off, what should I look for? Spridgets 20
S oil pan bolt Other Cars 9
hondo402000 Oil pan heater Triumph 11
