Oil marks the spot....
mjobrien
OK, help me out a little if you can. Is it crazy to attempt to stop every oil leak on a 55 vintage Healey? I have most of the leaks stopped but the rear end (at main gasket) and oil pan are still leaking.
Has anyone used the string with gasket sealer trick or do I need to pull the axels and redo the gasket?
Should I can the cork gasket and go with make a gasket material or permatex like sealant?
Thanks in advance!
Michael
Dave Russell
Yoda - R.I.P
It's unusual for the main center section to leak. The gaskets I've seen are heavy paper, not cork. Are you sure that the pinion seal is not leaking & running back to the main joint. If by chance it is the pinion seal, they are not too hard to change.
Since you have to pull the axles to get the center part out, I'd consider waiting a bit. If you pull the axles, there will be the axle flange to bearing carrier seals & the main rear axle bearing seals to contend with also. Getting these parts reinstalled AND sealed can be quite a task.
Ed_K
Hi Michael,
I couldn't tell that my rear axle was leaking in two different places until after I replaced the pinion seal. Then I was able to see the leak from the bottom . Keoke or Dave,( I can't remember which ), suggested that I try loosening the bottom four nuts on the rear axle and then sealing up the base of the threads with some gasket/sealer I used Permatex RTV under the washers and nuts and then tightened them back down. That stopped the leak without taking all of the nuts loose and using Coastalman's string trick.
Ed
mjobrien
mjobrien
Dave, Ed,
Both suggestions sound logical, I'll wait a bit and also do a little sealing around the bottom bolts. After a few wipes and a check a day or so later it does appear that this is the main seal and the pinion seal is dry at least so far......
Hey if they didn't leak what would we do with our spare time when they are all done /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
K TR2/3/3A TR3 dipstick marks and oil level? Triumph 5
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
