Oil leak? High Idle?
Falkon
A few weeks ago finally got to the point in which i could start my Midget for the first time. Now that its running the next list of problems are starting to arise, as expected. Now with the electronic ignition installed, im sure my timing is not exact but close. The engine is idling at about 2k to 2.5k. After a bit it will lower to 1.5, any lower and it begins to misfire to often and die. I think the problem may be the combination of the carbs needing adjusting, the oil that im burning from some place and the timing being off. Otherwise its not over heating and it seems to be running strong. Any suggestions on what i should work on next or look into. Also what should my oil pressure be sitting at. Currently its hovering around 70-80 with the high rpm.
smaceng
The high idle speed will cause the timing to be advanced, as it needs to be set a a much lower speed. See if you can adjust the timing, even if just manually turning the distributor until you get the best idle. Remember to adjust both idle screws. Oil pressure is fine.
Make sure the pistons are free to move up and down using the little push rod underneath (engine off).then verify that both carbs are operating together at idle, i.e. that both pistons go up and down together and do not stick.
If all that works, write back
Scott in CA
nomad
Make sure there is oil in the piston dampners first then follow Scotts advise.
Kurt.
G
70-80 PSI oil pressure!? :shocked:
Can I borrow a few pounds? :jester:
Check for vacuum leaks as well.
Bayless
Got to have the ignition and valves right then check for vacuum leaks before messing with the carbs. Otherwise you just end up chasing your tail.
DRH
Got all your vacumn hoses hooked up? I've found that when an engine doesn't idle but runs well above 2000rpm then there is a vacum leak somewhere by the carbs. Spray some starting fluid around the intake manifold and the carbs and see if the rpm automatically rises. Rig up a straw for the nozzle so you can avoid any ether entering the system through the air cleaners. I even taped some lenghths of PVC pipe to the intake throat of the carbs to assure the test ether was not entering at that point. Barring any other problem, I've done it lots of times and it works. Bayless is right, you can go around in circles.
F
Falkon
I definitely do have a vacuum leak. I still haven't hooked up one of the vacuum lines because my local auto stores don't have the necessary connectors. Valves are knew and have been seated properly. I might pull the head off just to be double sure. As for the carbs, they have been completely rebuilt and the pistons do move smoothly up and down. With doing some looking around i think the carbs may be also running a bit rich. Ill get that Y vacuum connection that goes in between the carbs and go from there.
Bayless
Get the vacuum connections done. It'll never run right with a significant vacuum leak.
F
Falkon
All the vacuum lines are now connected and good. No leaks. It now seems to be running a bit smoother and the white smoke has gone away, but its still running at a high idle and still misfiring when i choke it down. At this point i think its a matter of adjusting the carbs. I do know they are running rich. Lifted the pistons up a bit and the idle speed up. Only thing is i really dont know how to properly adjust them. I know this is a process that needs to be done correctly. Does anyone have a good guide that i could use, or a video online? Tips and pointers would be helpful. Thanks everyone!
JPSmit
each carb has a nut on the bottom (with the needle) to make it leaner, turn the nut anti clockwise. richer, clockwise. typically you would turn one "flat" at a time ( 1/6 of a turn)
smaceng
JP, that may be a little confusing.....
What JP says is correct, looking from the top of the SU.
Normally we think of the nut as you look at it from the bottom up, which means clockwise is leaner, and counter-clockwise is richer.
Scott in CA
JPSmit
thanks Scott. you're right - from the top
Pythias
So, When looking down, to the Right, Richer, --They both start with R,
and to the Left, Leaner, ---they both start with L. ... but being British, it's on the wrong side, so backwards...
Nice Mnemonic.
nomad
Lots of info out there on balancing SU's. First make sure both butterflys are opening at exactly the same time. Oil in dashpot dampners then adjust the jets so that when raising the lifting pins the engine does not continue to increase in speed but just begins to level off or falter as the pin reaches its upper limit.
You really need a good manual to get a more complete description.
Kurt.
I MGB Sprung an (oil) Leak! MG 2
B Oil (or Coolant) Leak Austin Healey 10
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
B Phanton Oil Leak Spridgets 12
I Bugeye oil leak help Spridgets 4
Zitch Engine Oil Leak After Long Drive Austin Healey 19
2 TR2/3/3A Oil leak in tranny Triumph 4
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
steveg Strange Oil Leak Austin Healey 7
TomMull TR2/3/3A Transmission oil leak Triumph 17
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
D BT7 Oil Leak at Distributor Austin Healey 5
J TR4/4A Oil leak from rear of motor. Triumph 28
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
TR3MT TR2/3/3A Purolator Oil Filter Leak Triumph 10
T Oil pan leak? Spridgets 7
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
D Oil Leak at rear of oil pan Spridgets 11
Martinld123 Austin Healey BN2 oil leak at base of distributor Austin Healey 7
C oil leak Spridgets 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR2/3/3A Locating source of oil leak Triumph 6
Jim_Stevens TR2/3/3A Trunnions oil leak Triumph 2
D TR2/3/3A '59 TR3A oil pan leak Triumph 12
gbtr6 TR6 TR6 Oil Level, New Motor and Leak Triumph 16
Martinld123 Problems with Oil Leak From Distributor Austin Healey 2
T TR2/3/3A coil mounting bolt oil leak Triumph 2
4tecdog BJ8 Overdrive oil leak Austin Healey 6
H blow by oil pressure causes oil to leak out of the dip stick tube. Austin Healey 12
TulsaFred Front engine oil leak Spridgets 33
TulsaFred Fixed One Oil Leak, Found Another! Spridgets 12
Sixpack TR6 Bad Oil Leak Triumph 24
T Gear Oil Leak Austin Healey 17
Rut Bugeye oil leak Spridgets 8
J Found an oil leak Austin Healey 7
V Problems - Oil Leak and Manifold Pressure Austin Healey 1
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
RJS TR4/4A Oil leak at/on fuel pump Triumph 7
J Engine block modification for oil to water jacket leak Austin Healey 8
apbos We have Vroom, Vroom and an oil leak from the Oil Filter! Spridgets 11
Gliderman8 TR6 Oil Leak found! Now what? Triumph 26
S Rear crank seal oil leak BN2 Austin Healey 20
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
johnrip Wedge TR7 Oil Pump Leak Triumph 2
RJS Oil Leak Questions Triumph 10
dklawson Oil Leak - I Screwed Something Up. Triumph 8
Bob_Spidell Oil Leak BN2 Austin Healey 2
