Oil capacity after spin on adapter conversion
jerrybny
Good morning one and all. I have converted my TR6's canister type oil filter with the spin on adapter. I am using a Fram PH3600 filter. While filling the oil I noticed that it took more oil than the 9 pints that manual said. Is this because of the new position of the oil filter which keeps more oil in it instead of it draining back into the oil pan? Should I put in oil until the dipstick reads full? Thanks
piman
Hello Jerry,
I have a spin on oil filter on my Triumph 2.5 PI and I just fill to the full mark. Theoretically, I suppose that the oil level will be slightly higher when running with the conversion than without as the original oil canister will have some oil in it when running and empties when stopped.
Alec
MGTF1250Dave
Aloha Jerry,
I use a PH3600 on my TR3 and it take a bit more oil to bring it up to the full mark on the dip stick. The backflow preventor feature in the filter not only keeps oil in the filter but also the upstream oil galleries. The great addvantage is instant oil pressure on start up which makes the spin oil filter conversion a good after market change.
Safety Fast,
Dave
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
PAUL161 MGB MGB Transmission Oil Capacity ? MG 2
A 100-4 oil capacity Austin Healey 3
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
B Aluminium sump and the effect on oil capacity Austin Healey 8
R Differential Oil Capacity Austin Healey 10
R # qts of oil, Capacity of radiator healey mk II BJ7 Austin Healey 8
H TR4/4A TR4 Oil Capacity Triumph 20
V Oil capacity of Datsun gearbox Spridgets 1
jvandyke oil capacity Spridgets 4
J TR2/3/3A TR3 Oil Capacity Triumph 7
healeyboz oil capacity Spridgets 1
P TR6 TR6 Oil Capacity? Triumph 7
davidk TR6 Transmission Oil Capacity on a non OD TR-6 Triumph 5
healeyboz Oil Capacity Spridgets 9
B Oil Capacity 3000 Austin Healey 36
msoylemez datsun 210 trans oil capacity Spridgets 4
jsneddon TR2/3/3A TR3 Transmission Oil Capacity Triumph 3
T GT6 Help on GT6 oil capacity Triumph 8
P Oil sump capacity Austin Healey 7
J Oil capacity MG 3
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
