Nut and wire Trick
philknight
Don't know if anybody else has had to resort to this but it worked for me.
I was installing a gear reduction starter and couldn't get the nut started onto the top bolt. Didn't want to remove the tunnel cover to get free access to it. Couldn't get a finger behind it and get the nut lined up. Tried duct taping the nut to the end of my pinky finger, but once I had it in there I couldn't see to line it up. Same thing happened taping the nut into a wrench. As a last resort before tearing out the interior I twisted a wire around the outside of the nut and fished it behind the bolt and turned the bolt. Eureka, it worked.
Geo Hahn
It's a good feeling when that thing threads in. I'll keep this one in mind... I've often resorted to the duct tape method.
martx-5
The wire thingie is a good idea that I'll store away in the memory banks.
I do a similar thing using a box wrench as you mentioned, but I use some paper between the nut and the box wrench to hold it in tightly. It depends on how loose the nut is in the box wrench with regards to how much paper is neccessary...but it isn't alot. Start out by laying a small pice of paper over the opening of the wrench, and then try to force the nut in. If it's too tight, just cover half of the opening. A little practice, and you'll get the knack.
mrv8q
I started similiar w/ Art above, but I put the nut into a Stubby box wrench, 9/16 ISTR? I then put a small piece of duct tape on the back of the box wrench, so the nut wouldn't fall thru and out. Inserted the bolt, took 5 seconds!. ISTR only the stubby gave me enough room back there....
P
philknight
I tried the stubby wrench as well, but still couldn't see past my hand to line up the nut.Ima tellina U there were some explatives yelled across the garage trying to get that nut started.
Brosky
Why do all car manufacturers mange to find a way to engineer at least one bolt/nut combo that is nearly impossible to get at through normal methods? Oldsmobile was touted as the enginering division of GM in the 50's and 60's and every 442 had a miserable bolt or nut to install. Other than that, everything was out in the open and it wouldn't have taken much to make every one accessable.
kc_doyle
I had a spark plug on a 383ci Dodge that I could only get out with a double universal. One click at a time. They had it hid behind the headers, behind the power brakes, against the firewall. The problem was, if I wanted to keep it running right I had to change plugs about every 1,000 miles. If ya think getting it out was fun, think about putting the new one in. I used a section of hose like that fit over the top of the plug, snaked it in and started it, then got a socket on it. ****, I loved that Super Bee.
P
philknight
I think they might just have a sadistic sense of humor.
There is probably an old guy in Coventry snickering right about now.
P
philknight
Had a 91 Formula Firebird that had plugs that were a pain to get to. It was quick and cornered extremely well for such a large car. Brilliant me decided to take it to Precision Tune for tune ups so it would be their problem not mine. Bad Idea. When I had it for sale I took a potential buyer on a test drive and opened it up on a back road and heard a pop. Turns out when they do a tune up they only change plugs that aren't firing. Well this perticular plug must have been good until it rusted enough that the plug shot out leaving the threaded part in the head.
Brosky
He's the same wise guy who designed the bolts that go through coolant and oil jackets in the block and then leak after a few years. Snicker, snicker.....
bighealeysource nut stuck on wire wheel hub on BN2 Austin Healey 18
H 1966 BJ8 Steering Box Leak @ Wire Compression Nut Austin Healey 7
B MGA Where to Buy, What to Buy? Axle Nut MG 9
C Steering Arm Castle Nut Torque Austin Healey 5
R Vixen 2500 Lug Nut Size? TVR 5
B General MG Crankshaft Nut Removal MG 4
drooartz Modifying castle nut Restoration & Tools 3
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
G Stator Tube Nut and Olive Austin Healey 9
dbenichou289 TR2/3/3A Shifter knob jam nut Triumph 2
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
jfarris TR2/3/3A Castellated nut on the pinion Triumph 9
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
AN6-TX Hex Nut 2BA? Austin Healey 4
K TR2/3/3A The nut and the olive...no not a Mediterranean snack? Triumph 6
J Nut size for BJ8 center console trim piece Austin Healey 8
K TR2/3/3A The Steering Wheel Nut Triumph 20
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
B TR2/3/3A Lug Nut use Triumph 3
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
tahoe healey cool air pull knob nut Austin Healey 15
S TR2/3/3A correct spire nut Triumph 4
S stator tube nut Austin Healey 7
K Correct side screen nut for early 58 BN4 Austin Healey 14
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
S TR2/3/3A little caged nut headlights Triumph 2
H Windshield Post to Body - Captive nut needs to be replaced - Pillar to Body Spridgets 2
C Size of axle bearing nut Austin Healey 11
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
GeorgeC Steering wheel nut size? Spridgets 3
I How to undo a flange nut..? Austin Healey 11
G Torque for Front Pinion Nut Austin Healey 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
Rut TR4/4A steering shaft/nut thread size Triumph 5
Tinkerman TR2/3/3A TR3A SU H6 Rebuild Float chamber Cap Nut Triumph 3
drooartz Diff pinion nut Spridgets 10
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
M 948 Pulley Nut Size Spridgets 1
J Rounded hub nut on my 63 BJ7 Austin Healey 25
Z Early BN1 front stub axle castellated nut Austin Healey 3
C TR2/3/3A Nut cages. Triumph 3
croz TR2/3/3A Heater tap locking nut Triumph 8
Griz Manifold nut torque Austin Healey 11
