TR6 New Alternator Rec.
PanP
Member
Hello forum,
I Have a shorted volt reg on my 1973 tr6 alt. Does anyone have a recomendation for a replacement Alt. I am not opposed to wireing a new plug on, just want to make sure bolt holes and pully line up. I would like a little higher amp say 60 or so. I have heard some GM alts would work, don't know which model #. Any help would great. Thanks
Not sure how available they are now, but there is a Bosch alternator that bolts right up, same plug and everything. Original application was 78-80 Ford Fiesta with AC (or with Bosch alternator). Don't be fooled and get the Motorcraft alternator, it doesn't mount the same.
Rated 55 amps as I recall, but delivers it at much lower rpm than the old Lucas does. We put one on a buddy's TR6 and it would keep up with his high power stereo at idle. Don't recall for certain, we might have had to move his old pulley to the Bosch.
I believe you can also buy replacement regulators for the old Lucas.
Thanks TR3driver, haven't looked into a regulator replacement yet. Not sure if I even want to keep the lucas, sounds like maybe a bearing is about to give also.
Here's the Fiesta on my 74..Pretty much a plug and play although the fan belt is 1/2 " longer than the one you see in the TR6 parts catalog for the 74.
The application is for 78 to 80 Ford Fiesta with A/C and rear window defrost.
Here's the GM 7127 in my 73.
A few more mods required, but it's availability and lifetime warranty from AutoZone make it attractive.
If you do go the Bosch 55 amp route, don't make the mistake I did, make sure that it comes with a fan and pulley before plunking down your money. I did this many years ago and found out the hard way that it was a tough size to match up (at least at that time) and of course, the one I bought had no fan or pulley included. I wound up going junk yarding online to find a dead Fiesta with the correct alternator just to get a fan and pulley. A couple of hour drive later and I had it but I don't know how much luck you'd have finding one today, those old Fiestas weren't all that common then and are all pretty much out of the system by now. From a Ford and Bosch perspective, they were NLS when I was looking for them.
That's a good point about the Bosch. I brought the fan and pulley from my Lucas to a machinist to enlarge the holes to fit the Bosch shaft..I believe he charged 12.00.
Thanks everybody for the suggestions, I am considering the 110 amp by Rareelctrical, I know its a bit overkill but has the pulley and just needs minor wire in. Not sure about bracket. Rustbucket say minor modification. We will see..
If I recall correctly, all I had to do was grind some off the boss where the tab that the mounting bolt goes through to line up the pulleys, and clearance the front plate on the engine a little. I'll take some pics next time I have the hood up, which is pretty often!
So, I bought the Rareelectrical 110a I can't quite understand if I am wiring the unit correctly. I did have to shave the spacers a bit, but mounted up real nice. As of now I can not get a charge to the battery, volt meter shows less than 12 when engine running. I though the instructions were clear, but they did not say what to due with the small separate brown plug from the existing alt. I have a 73' with 2 large brown and 1 small brown/yellow on the plug and than a separate small brown plug.
The instructions said to combine the 2brwn with the red wire from the new alt and attach to the bat lug on back of alt. Than attach my brn/yellow to the 2 brwns on the alt plug. and leave the grey as acc. No mention what to do with my other small bwn plug? I know this is a little hard to visualize without a picture, I will try to take one.
I noticed none of the wiring diagrams show the 4th wire with separate plug going to the original alternator. Can someone tell me what this was for?
Thanks
Brian
Check page 86.00.02 in the workshop manual, I believe it shows the extra wire. I believe it was the "sense" wire, that lets the voltage regulator "see" a more accurate picture of battery voltage (without being fooled by the voltage drop through the main output wire).
From the description, I'm pretty sure you don't need the old sense line. Just tie it back and insulate it, so it can't touch anything. It's wired directly to the battery, so it will let the smoke out if it touches anything.
Linking either one of the big brown wires to the red wire and the output lug on the alternator should be enough to make it work, at least a little bit. Sounds to me like it has gotten damaged somehow and no longer works. You might take a voltmeter or test light and double-check that you can see battery voltage at the lug, with the engine off. It's possible (though not likely I would think) that there is a problem where they attach to the battery cable. Also worth checking that the voltage at the lug doesn't go up with the engine running at fast idle.
PS, I don't mean to say that you shouldn't wire both big brown wires to the output lug; only that it should work some even with only one connected.
Turns out to be a bad Alternator. Sent it back to Rareelectrical for a replacement. They were very responsive and easy to deal with although I did have to pay for shipping to return the defective unit, one of the downsides to buying online :(
New one should be here this week hope I have better luck. If all else fails I will be getting a common Delco from Oriely Auto and modifing the mounts to make it work, probably should have done that in the first place.
P Generator-to-Alternator Conversion Austin Healey 7
T TR6 Alternator wiring Triumph 6
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
PAUL161 T-Series Dynamator Alternator conversion. MG 23
P '58 XK150 Dynalite Alternator swap question Jaguar 5
B Delayed charging Lucas alternator Triumph 1
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
Walter74 Dynamo to alternator Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
donbmw TR2/3/3A Converted to alternator Triumph 14
90dog A H Spares Alternator Bracket Austin Healey 53
R TR2/3/3A generator to alternator Triumph 5
JPSmit Alternator help - please. Spridgets 21
I Bugeye generator/alternator conversion question Spridgets 7
Ripper01 TR6 110A Alternator Triumph 7
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
Sopwith_Camel alternator eater Spridgets 20
longbridgehealey Alternator conversion and tach Austin Healey 9
S TR2/3/3A Alternator Triumph 7
apbos Positive Ground Alternator wiring. Spridgets 9
BoyRacer Wiring question for alternator conversion Austin Healey 3
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
