TR6 Need TR6 Brake Caliper Brackets
PatGalvin
I'm in search of a pair of TR6 brake caliper brackets. I am installing Toyota front calipers on my TR3A. Purchased 7/16th bolts with metric shoulders from TRF. Purchased two new TR6 rotors from TRF. Purchased Toyota calipers from Rock Auto. And now, as I'm fitting it up, I find that the calipers absolutely won't fit over the rotors. A handy search on this life-saving forum resulted in the realization that my TR3 calipers won't work and that I need to use the TR6 calipers to move the caliper out, off the rotor. Anybody got a pair they would be willing to sell me? Photo shows the difference between TR3 and TR6 bracket.
Or do you know where I can purchase these items? I live in Northern CA.
Thanks very much.
PM me and I'll send you my contact info.
Pat
Brosky
I may have a pair from some suspension parts swapping, but I can't check until Monday. I'll get back to you as soon as I know for sure that they are there.
martx-5
PeterK said:
Just thinking ... dust shields?
Depends on the year of the TR3...the earlier cars (like mine...TS23xxx) didn't come with dust shields. Also, if you do have dust shields, they will have to be trimmed whether they are TR3 or TR6.
Edit: Piggott says they introduced the dust shield at TS27689...
PatGalvin
PatGalvin
Trimming for the TR3 caliper bracket was minor to fit the Toyota caliper. Of course, the caliper doesn't fit over the rotor using the TR3 bracket so that was an unfortunate waste of time. I'll take a photo of trimming required when using TR6 caliper bracket, if I can find a pair. I've emailed a few parts suppliers to see if someone might have these to sell. Happy to trade TR3 suspension parts or powder coating services for a couple caliper brackets. I also ave an extra TR3A rolling chassis that I won't be needing, if any takers.
Pat
Looks great, rotors won't fit with TR3 caliper bracket.
approximate trim on backing plate, thus far. Maybe trim more with TR6 bracket? We'll see.
martx-5
I also made a couple of brackets for the hydraulic lines...see pics below...
PatGalvin
PatGalvin
Flat brake hose "L" bracket attaches to what? Lower caliper mounting bolt? Thanks. Nice work. Love those drilled rotors.
Pat
PatGalvin
PatGalvin
So how did you do your brake hose setup? Did you make hard pipe adapter (metric to standard) and then use standard stainless hose? Very clean setup so I'm interested in duplicating this arrangement. Nice work. Thanks
Pat
PeterK
I made my own conversion lines too. The hardest part was the small radius bend then 90 deg to prevent the line from fouling into the coil springs at full lock.
This is on my 4A
Notice the green metric line nut at the caliper. It's an off the shelf Japanese line from the auto parts store. I added a british end and flared to fit the TR braided coupler.
Brosky
Pat,
Did you get them from John? I can't find mine and he is in CA, so you could have those right away.
Sorry,
Paul
martx-5
Dr. Marty offers the whole conversion kit for the TR6 including the drilled rotors. Since I had access to the calipers, I just bought the rotors, metric to SAE hard line and the caliper bolts from him. I believe that the metric/SAE hard line is available separately from various sources.
The bracket is bolted onto the upper caliper bolt. I kinda fabbed them up in situ. First mounting the bracket straight up, then bending the ell and twisting to meet the flex line where I wanted it, drill in the hole for the flex line, and cutting off any excess.
You'll notice in the picture that I don't have the coil springs in yet. That was so I could see how the flex line moved through the complete up and down and side to side movement of the suspension and steering. You might have to make some final tweaks on the twist after going through the range of motions.
Yeah, the drilled rotors...just some bling. I doubt they do any good. I needed rotors anyway.
PatGalvin
PatGalvin
Hi John
I sent you a PM but am not certain I'm using that feature properly. My email address is:
patdotgalvinatgmaildotcom
Email me your contact info and I'll arrange to send you the cash.
Regards,
Pat
PatGalvin
PatGalvin
Good idea on leaving the spring out until after you check suspension travel and brake hose interference. I don't relish removing the spring again but probably should do the same and ensure I've set this up properly.
What a learning experience. I'll have assembled everything two or three times before I'm done with this....
Pat
S TR6 Need wisdom on tr6 brake calipers Triumph 6
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
Got_All_4 TR6 Need a frame for TR6 Triumph 21
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
C TR6 Need help with a 1969 triumph tr6 Triumph 21
L TR6 need help on long dead TR6 Triumph 16
S TR6 Help! Need help from TR experts with this frustrating TR6 pushrod/rocker/valve issue Triumph 23
Gliderman8 TR6 Need battery info please for TR6 Triumph 4
2wrench TR6 Need help with '74 TR6 speedometer. Triumph 12
R TR6 Need Photo of DS Wiring Harness Route '71 TR6 Triumph 0
I TR6 Need help on 69 TR6 glove box info Triumph 0
I TR6 Need measurement for tr6 kidney pad please Triumph 4
I TR6 TR6 enine running hot - need some adivce Triumph 40
hondo402000 TR6 Need Help on 71 TR6 Overdrive Wiring Triumph 9
hondo402000 TR6 71 TR6 Hazzard Switch[need one] Triumph 8
B TR6 Need a few opinions on parting out/pricing for TR6 Triumph 8
C TR6 Need a TR6 rim Triumph 1
I TR6 Boring subject, but still need help TR6 trim rings Triumph 6
B TR6 Need guidance on TR6 electrical issue Triumph 7
T TR6 Scary TR6 sill pictures - anyone need yard fill? Triumph 10
T TR6 need a plug for my late model tr6 head Triumph 12
T TR6 Does a TR6 need an engine to chassis ground strap? Triumph 16
amcboy TR6 I need a TR6 part, or dimensions, or swatted. Triumph 2
N TR6 need the carb mounting stud size for 1974 TR6 Triumph 14
T TR6 Need a TR6 photo Triumph 1
V TR6 Need a Transmission cooler for your TR6? Triumph 4
Got_All_4 TR6 Question and need for a 69 TR6 seat Triumph 1
K TR6 tr6 differential - need feedback! Triumph 16
T TR6 need center radio support tr6 Triumph 4
A TR6 Need TR6 shift lever measurement Triumph 4
T TR6 tr6 intake-if i had one-i'd need this soooo bad Triumph 10
I TR6 Need more headlight help, TR6 Triumph 4
F TR6 Need help w/TR6 oil cooler install... Triumph 16
N TR6 Need drawings for Miata seat mounts in a TR6 Triumph 4
DNK TR6 Need help with a TR6 Tunnel lamp Triumph 12
hondo402000 TR6 need a used dash for 71 TR6 Triumph 1
2wrench TR6 Need help removing glass from '74 TR6 windscreen. Triumph 13
C TR6 I need a little help....quick measurment on a TR6 Triumph 2
A TR6 Need clutch hydralic line ideas [TR6] Triumph 24
2wrench TR6 Need help on '74 TR6 windscreen frame removal Triumph 6
T TR6 "Might as well" if you need to pull the TR6 dash Triumph 6
2wrench TR6 Need replacement bulbs ID'd for under dash '74 TR6 Triumph 4
G TR6 Need a part from an early TR6/250 Triumph 9
A TR6 Need a torque setting for rear axle?? [TR6] Triumph 1
N TR6 Need TR6 distributor advance weight spring Triumph 3
G TR6 Need a part for a TR6 Triumph 1
