need help with dist cap conversion!!!
gokuboy26
Hi folks!
I have a 66 midget. It has the 25D distributor. The cap has the wires that come out the side... I wanted to upgrade it so the wires can come out the top.
I was told the cap with lucas part number DDB106 would work with it. I got the cap, it fits perfect... I swapped out the cap and wires, but now I get no spark at all.
The rotor is new, but I had replaced it a few months back.
I'm not sure if it makes a difference, but it does have the pertronix ignition...
Any ideas? Am I wrong to assume the stock side-wires cap can be converted to a top wire?
taskadog
I don't know the correct part #, but if the cap fits well the only two probems could be cap or rotor.
Try a new roter and if that doen't work, return the cap as defective.
This assumes your connections (wires) to the cap are making good contact.
Phil
bthompson
Odd...I have a 25D with Pertronix and a top-wire cap. (Just specify a cap for an MGB instead of a Midget at your local auto parts store, that's what works for me.) The caps should be interchangable, so what works for one should work for another. Are your wires firmly plugged in? Sounds silly, but my replacement wires had their boots way too close to the end of the leads...They looked like they were plugged tight, but weren't making contact. I had to slide the boots back about an inch to make sure they were pushed fully home.
G
gokuboy26
I'll double check all the connections tomorrow. hopefully thats all it is... The rotor still looks new... so my gut says thats probably not it...
My wires caps were actually not pushed on far enough... tomorrow I'll pull everything and redo the wiring. I'll let you know how it goes.
I'll also post a pic of the car so you can see my toy!
G
gokuboy26
Here it is.
Technically its my Dad's car... I'm fixing it up for him.
I owed him some money, and got this for him instead (with his approval! lol)
My LBCs are a 58 TR3, and a 69 Spitfire.
Cost for the midget was $900 last spring... it wasnt running.
I put in a new ignition switch and battery, and it got running!
dklawson
Another silly question (and thing to check)... did you remember to put the rotor in the dizzy before fitting the cap? It's happened to most of us at one time or another.
Those plug wires seem dangerously long.
scoutll
Also, make sure the little spring loaded center contact is in the cap. Over the years, I have found a couple of new caps where it has fallen out.
Pythias
the big question is did the cap and rotor come from Jeff at ADVANCE DISTRIBUTORS? ... if so the problem is in the coil or the plug wires. If not, WHY not? Get A Red Rotor from him.
NFI
G
gokuboy26
I'm feeling dumb... it was just the plug wires... I was thinking it had to be something else because i didnt have any backfires at all. :smile: thanks for all your help!
JPSmit
And may I say on behalf of the entire board that this is the first time that has ever happened.
Seriously, I don't think there is one of us who hasn't done that or something similar, I can't tell you the number of times I have overlooked the simple stuff. welcome to the club, you're in good company! :cheers:
bill_powell
A couple of months ago I spent about 1/2 an hour sitting in a Lowe's parking lot trying to figure out why my car would not start, or even turn over. Totally dead. I checked over everything I could think of. Couldn't find anything wrong. I mean nothing. Nada.
See this switch? The big honking red one to the left of the gauge?
That's the battery cut-off switch I installed last year. The one I had obviously bumped by accident to the 'off' position in the parking lot. I turned it back on. The car started right up.
Sometimes I'm so stupid I amaze myself.
G
gokuboy26
So, I'm still getting some backfiring upon revving the engine...
I'm thinking the timing is off... and I'm also eyeballing the vacuum advance line... which, if you look in the picture is old, gnarled, and metal...
First I'm going to time it... the timing marks look to be on the underside of the crank pulley. so... if I'm using the strobe from underneath the car I won't be able to reach the distributor.... is timing then a 2 person job?
dklawson
Jeff at Advanced Distributors sells a timing tape and pointer kit for the 1275 that will allow you to put timing marks "up" where you can see them. Just Google "Advanced Distributors" and follow the products link to find the pointer kit. I don't know if the kit is suitable for other engine sizes. Jeff would be able to answer that.
You said the engine backfires when revved. Is the backfire under the bonnet or out the tailpipe?
The vacuum advance really only does its thing at cruising speed. If you feel it is creating an air leak, remove the line at the carb and plug the carb port during your tuning.
G
gokuboy26
It backfires out the carb, so, under the bonnet
JPSmit
backfire under carb is pre-ignition - you are running too lean.
dklawson
As John-Peter said, the backfire may be fuel/mixture related and not related to your recent ignition component changes. It may not be simply a mixture issue though. You may be running on one carb due to blockage or a hung float valve, or there may be heavy deposits limiting fuel through the main jet/needle. Gummed up carbs are fairly common on cars that were parked and left for a long time with fuel in the float bowls.
G
gokuboy26
well... This car DID sit for about 2 years prior to coming into my possession, so thats going to be the first thing I will do then... I'll clean out the carbs, and if that doesn't help... adjust the mixture... and if that doesn't work,,.. then it would stand to reason a rebuild would be in order.
Thanks guys
JPSmit
You are over complicating things.
1. if it runs, the fuel is OK - you might want to run some sea foam or something at some point BUT, the carbs work now - DON'T mess with them re cleaning.
2. If it runs, and backfires, timing might be an issues but, mixture is more likely the issue.(and maybe vacuum? - I don't know much about vacuum so I am going to let someone else wade in - tough if it is metal, there's a pretty good chance it is tight even if knarly.)
3. Get it running (under load if possible) turn it off and check your plugs. you can post pics here or, there are many pics on the net. The colour of the plugs will tell you what you need to know.
4. Lean or rich is turning the one nut under the carb (and balancing) Sort this out first before you start worrying about timing or cleaning or you will drive yourself crazy! (don't ask me how I know)
One factor at a time.
Bayless
Starting on a car with unknown history, I would always recommend at least checking the electrical tune, points, dwell and timing first. This only takes a few minutes at most. If those are off, you'll likely never get it running right. Then if you do a bunch of fiddling with the carbs and eventually have to correct the electrical, you'll just have to start all over on the carbs later.
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
B TR2/3/3A Need help with tr3 project Triumph 9
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
Steve P. Need help with oil filters Spridgets 1
RickPA Need help installing steering idler oil seal Austin Healey 6
M TR4/4A Need help with TR4A brakes Triumph 10
Willie_P TR4/4A Alloy Valve cover: STUD SPECIFICATION - need help!!! Triumph 5
Rut MGB Need turn signal help MG 15
D Need help please Spridgets 4
