TR2/3/3A Need Help with 62 TR3A
jkenley
This is Jack. Working on 62 TR3A . Found a switch underneath the dash located close to the heater. Need help in identifying it. Im a little rusty with this TR as my last project was a Bugeye back in early 70's. Take a look and let me know if you recognize this switch. Thx
TR3driver
Great Pumpkin - R.I.P
Definitely not original; just a common FLAPS replacement switch (tho likely from several decades back). So it could control almost anything. But if I had to guess, my guess would be kill switch.
billspit
It is likely a secret kill switch, a switch for the passenger ejection seat, or a switch for the Romulan cloaking device.
sp53
Nice looking tr3 at least under the dash, very stock looking. It looks to have the original heater hoses or perhaps replica aftermarket. Plus still has the brass holder for the temp gauge line. Be very careful around that line because if that lines breaks the gas comes out and the temp gauge will not work. Welcome to the forum—kill switch for something-- trace the wires back, could be anything—except a time machine or something like that; well if it is let me know, I have some stuff I would like to change.
peaceout
PeterK TR2/3/3A Need help with TR3A top install Triumph 12
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
B TR2/3/3A Need help with tr3 project Triumph 9
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
Steve P. Need help with oil filters Spridgets 1
RickPA Need help installing steering idler oil seal Austin Healey 6
M TR4/4A Need help with TR4A brakes Triumph 10
Willie_P TR4/4A Alloy Valve cover: STUD SPECIFICATION - need help!!! Triumph 5
Rut MGB Need turn signal help MG 15
D Need help please Spridgets 4
