Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo
volunteer
volunteer
Got the stop light switch at my local Lordco - overnight from Coast and total cost $18, (CDN). Still need info on SU pump operation so will seek out used replacement. Also no dash/gauge lights and front small, round marker lights seem to work one day but then not for weeks. (sigh). Someone else can deal with door and window seals and minor cosmetic detailing. Summer almost over so car will sit for another winter.
LarryK
Might be ground behind dash for the dash lights, also an area of wires getting hot behind ign. ,and fender grounds for maker lights, inside fender or in engine compartment near radiator.
volunteer
volunteer
Thanks. I'll look into this - but still feeling a bit 'blah'. Several years ago I replaced small, noisy fuel pump on '68 E-type with small, generic, low-pressure, quiet, (Carter?) pump and it worked great. Now thinking about doing same to Limo - where new pump can replace the faulty S.U. Is this possible? If not - why not? thanks.
EDITED: I did go ahead and install small generic electric pump - self priming and low pressure about same as OEM SU. So far so good.
volunteer
volunteer
Car finally on the road after almost 22 years. I have another thread in here about my Master Cylinder woes. I will find it and update but will post here also that I got all four wheels stopping fine. The weather stripping all available in England - but - very pricey. Next owner can do it.
NOW - thinking about replacing rear window. (sigh)
T Need Help with Door Seals MG 13
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
R TR4/4A Door Handle Question - Need the Wisdom of the Wizards of BCF Triumph 9
PHerder Door Parts missing :[ Need to beg, buy or steal... Spridgets 0
F Need help finding a part- door window track piece Austin Healey 5
W I need a door panel pattern Spridgets 3
mgnewbie need driver-side door mirror MG 3
eschneider need help - door ID Austin Healey 5
toysrrus TR4/4A My TR4 got "CRUNCHED" Today!!!!! Need Door!!!!! Triumph 46
Jack_Long Need help with door glass MG 2
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
