Need a picture please!
Putting the door rubber edging/trim on. Have all of it around doors. I think I know how the rubber goes down the w/s frame and then over onto the fender but anyone has a picture of that area that would be great. How many places have the rubber boots or caps on the ends of the trim? getting much closer,
thx.Marv
vette
This is the stuff from McGregor in Canada. And he told me exactly how to put it on. Don't cut it at the bottom of the windshield post, bend it, maybe put a little kink in it with wide blade cold chisle and tap it on with a soft blow hammer. But I never thought to ask him about what to do with the caps. I don't think the cap on the verticle edge coming up the door opening is correct. But the actual pieces of furflex or whatever it is called are the best that can be had.
Marvin Gruber
Thx Vette, kinda the way I thought. A BJ8 w/s frame is different but think it will work the same. Arent there caps on the top of this A post trim?
Marv
vette
Marv, my car is a BJ7, i didn't know the BJ8 windshield is different than mine. How so?
Marvin Gruber
Vette,
My bad , its not. I saw the dash metal dash and thought it was an earlier car. Thats what I will be doing this morning.
thx,
Marv
C Hub Puller...need picture Please! Austin Healey 4
R Need picture [s] of a BN7 or BT7 Servo installation Austin Healey 3
J Need a picture of how the transmission mounts to the frame. Triumph 3
1 No picture...but, I still need your help... British Motorbikes 7
Trevor Jessie Need a picture. Spridgets 11
T Spitfire Help and Picture need for a mk1 spitfire Triumph 1
JPSmit I need a picture or two Spridgets 0
regularman Need a picture of a midget with the top off. Spridgets 7
P Spridget racers... need picture of... Spridgets 4
L Still need a picture Spridgets 9
J I need a picture of installed fuel pump for BJ8. Austin Healey 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
