No picture...but, I still need your help...
198686d
Hello guys: A few weeks ago I forumed in about my "new" 1968 BSA Starfire single 250cc with 5,400 original miles. You all responded "we want pictures". I hate to admint this, but I do have pictures on my computer, but I don't know how to insert them here. My secretary couldn't even figure it out.
My excuse: I'm way older than the BSA.
But, now I really need your help!
Bike looks original and perfect, however, it's taking me 35 minutes to kick it over before it starts. My leg is falling off & my valve surgery doesn't like it. Electronic ignition?
Is that where I should start? Also, bike only has center stand. It's too darn heavy for me to get her up on that. Side stand? Where can I get one?
I hope you guys can help me, because here in St. louis. A British Motorcycle is an oxymoron.
Bowing down in thanks in advance.
dave in University City, MO
60 AH BugEye
04 Mini Cooper S
04 Vespa ET4
and now...68 BSA Starfire
First
Pictures- use the full reply screen (found at the bottom of the reply box at the end of every post). At the bottom is a post options box- in this box click on file manager- a new window will open and allow you to browse to the picture you would like to upload. there are file size limits (100 kb?). You may attach several files at once. When done adding files click done adding files. You pics will now be in your post.
Alternately you can post to a site like photbucket and then post a link here. Be sure you album is shared or public.
Hard starting
Do you have good spark?
What form of carb do you have on the bike? Amal?
On the Amals there is a very small hole behind the idle mixture screw that needs to be clear. I have had good luck wusing the smallest torch tip cleaner in my set.
mark
198686d
Mark: Thanks for "how to" on the photos. Yes, it's an Amal Carb. I'll follow through with your tip on that. Appreciate the tip.
dave
TRMark
Bronze
I bought a manual and CD for my 78 Bonneville on ebay, it has been a great help with trouble shooting and maintenance. I too have a hard time getting the bike up on the center stand. I have a small set of homemade ramps I build for getting cars up bit for changing oil. I run the front tire of my bike up the ramp and then push down the center stand. I also bought an ATV lift from Harbor Freight and modified it slightly, I like using it better than the center stand for some maintenance.
Lift
jessebogan
See your other thread for starting info. I kept points because A they always work, and B they are REALLY unlikely to fail someplace and leave you stranded. Seriously, if it takes more than one or two kicks, something is wrong. Learn the starting technique, and make sure the carb slide is perfect, and then timing and point/condensor condition. I ALWAYS use genuine LUCAS parts for all electrical components, and never had any trouble at all, in over 10 years of riding pleasure.
tony barnhill
Great Pumpkin - R.I.P
Is the fuel flow valve under the tank open?
198686d
Jesse......thanks, I did keep the other thread for starting information. Very helpful, as is your latest message. I'm sticking with the points. Right now looking for "as original as possible tires". It has the 68 orig. tires on now, but they, of course, are dry rotted even though they hold air.
thanks,
dave
jessebogan
Buy the best possible tires you can find. Your life depends on it. Tire technology improvements have drastically improved motorcycle safety. Metsler (sp?) makes really good tires, as does pirelli, avon, and probably others.
L Still need a picture Spridgets 9
Tinkerman Speedo Drive new picture still ????????????????? Triumph 2
K TR2/3/3A Picture of the Zinc washer. Triumph 3
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
L Do you have a picture of these convertible top details? Spridgets 4
lram59 TR4/4A What's wrong with this picture? Triumph 4
T TR2/3/3A Wanted - Picture of TR3A original firewall layout Triumph 5
steveg Picture needed - front turn light Austin Healey 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
S TR4/4A Identify piece with a picture Triumph 7
steveg Great AH picture gallery Austin Healey 1
maxwedge5281 Driving Lights [picture posting opportunity!] Austin Healey 25
Marvin Gruber Need a picture please! Austin Healey 8
HealeyRick Sprite Factory Picture Spridgets 3
Marvin Gruber BJ8 brake booster picture Austin Healey 4
C Overdrive throttle switch rod connection picture Austin Healey 3
C Hub Puller...need picture Please! Austin Healey 4
S Your picture on road to Le Mans & Le Mans classic Spotted 8
T TR2/3/3A Requesting some picture of the outer Rocker panel Triumph 19
Elva164 2014 VRG Turkey Bowl Video/Picture Thread! Racing 4
M General TR Restoration done, Picture time Triumph 33
P Bugeye front drum brake picture Spridgets 7
J Rocker valve assembly picture Austin Healey 6
Elva164 2014 PVGP Video/Picture Thread! Racing 32
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
thechileman TR4/4A Cool Picture.. Triumph 6
J Picture of temp gauge , Austin Mini British Motor Corp 2
D TR6 "big picture" engine diagram? Triumph 2
R Need picture [s] of a BN7 or BT7 Servo installation Austin Healey 3
Brinkerhoff TR2/3/3A TR3A steering column grommet - picture? Triumph 2
drooartz First picture of the family mini-fleet Spridgets 12
J TR2/3/3A Picture of painted substructure, finally! Triumph 8
G `Request for Overdrive Speemometer Cable Routing Picture Triumph 0
M TR2/3/3A TR3 heater install picture needed Triumph 33
J Need a picture of how the transmission mounts to the frame. Triumph 3
John Turney Another picture question FORUM Navigation Questions 0
Tinkerman TR 3 Picture HELP Needed Triumph 5
CJD Picture of an early widescreen frame Triumph 28
P TR6 What happened to my TR6 picture? Triumph 1
mgedit Wedge Wedge Style Sidescreen ... Picture Request Triumph 8
HEALEYJAG cam specs for 100, 100-M.....bracket picture 100-M Austin Healey 8
dklawson Post-War Other Picture Needed - Herald and/or Vitesse Speedometer Triumph 8
B MGB anyone have a good picture of a 78 MGB dashboard? MG 2
M T-Series Looking for a picture of my MG-TF V8 form the sixt MG 1
B Second picture. I don't quite get this yet Triumph 1
S Old [for me] picture Spridgets 9
R posting a picture FORUM Navigation Questions 3
richberman picture of radiator side shields anyone? Austin Healey 10
N Picture series BJ8 distributor and carburettors Austin Healey 3
wangdango Bonnet striker plate detail picture/advice? Austin Healey 0
