MSD Alternator
Keoke
Nope, What chu planing to fit Lin, a couple of search lights??---Keoke- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Lin
Lin
Keoke,
Well let's see, there is my refrigerator, my espresso maker, and my son's playstation.
Lin
GregW
Don’t forget the shaver, hair dryer, reading lamp, stock ticker and 6 subwoofers. One MUST find ways to occupy oneself during the dull commute to work.
I don't think the alternator would be so out of place on my car; I'm hardly a slave to originality (though with some effort, the car could be returned to original by its next owner).
The one modification I haven't yet done, and consider essential, is to fit heated seat elements (no heater in my car). For that, I think the alternator would be a good idea.
vette
Greg, What commute in a Healey could be dull? I Know you misspoke.
GregW
Hi Lin,
Getting back to your question… That alternator looks very cool. The one thing I wonder, is how much power that thing robs from the engine. Does a 105 amp alternator need more horsepower than a 60 amper? If that’s true, I think the MSD would do more harm than good since you’ll probably never need that much amperage in a Healey. Just a thought not based on any real facts that I am aware of.
Dave Russell
Yoda - R.I.P
Either alternator will only consume horsepower proportional to the load that is actually put on it.
At no load, either one will consume very little power. If the 60 amp alternator or the 105 were loaded to 60 amps they would both consume roughly 2.25 horsepower. If the 105 amp alternator were fully loaded, it would consume about 3.9 horsepower. It's doubtful if you could actually load the 105 amp unit to this load, unless you used some very heavy wire between alternator & load.
The 105 is likely to be considerably larger & more expensive. An alternator that is larger than the wiring capacity would cause hot wires with no gain.
GregW
Thanks Dave,
Good to know. I looked at the prices of those things, they run around $400 (including tax). More than I would want to spend (no slight intended, Lin) but they sure are purdy.
Keoke
Yes I think that is true Dave. However, it might be possible that with a low battery the alternator may try to right the imballance quickly and suppy more current than the original wiring was designed to handle.---Keoke
Lin
Lin
Greg,
No offense taken. I don't know that I will pursue the MSD at all. I was attracted because of the near universal mounting system and because as you say, it is "purdy." But, price and overkill are certainly mitigating factors.
I would still like to go back to my original question, which was, "has anyone used one of these?" I guess from the responses so far, the answer is "no."
Dave,
Thanks for the thoughts on HP usage.
Lin
1960 BT7 in restoration
1959 Bugeye
AJAX50
I read recently of an alternator that looked like a traditional dynamo being avaiable.I think it was SC spares in the UK. I have to say though that if the battery and other electrical parts are OK and the car is in a good state of tune then the traditional dynamo is well up to the task.
Gerard MSD Tach driver w/ Spridget tach Spridgets 15
richberman MSD 6AL-2 wiring diagram anyone Austin Healey 3
Jim_Newman MSD Ignition and weird run-on Austin Healey 4
DNK MSD Triumph 0
Jim_Newman Pertronix + MSD ignition problem Austin Healey 6
Jim_Newman MSD Ignition Austin Healey 7
lbc_newbie MSD ignition or comparable with a 1275 Spridgets 17
hondo402000 MSD unit dies Triumph 12
Darrell_Walker TR4/4A Where to mount MSD box on TR4/4A Triumph 14
DNK MSD wires Triumph 0
PATR8 Tach not working [MSD Ignition system] Triumph 1
G MSD Ignition Triumph 15
T TR6 Alternator wiring Triumph 0
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
PAUL161 T-Series Dynamator Alternator conversion. MG 23
P '58 XK150 Dynalite Alternator swap question Jaguar 5
B Delayed charging Lucas alternator Triumph 1
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
Walter74 Dynamo to alternator Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
donbmw TR2/3/3A Converted to alternator Triumph 14
90dog A H Spares Alternator Bracket Austin Healey 53
R TR2/3/3A generator to alternator Triumph 5
