More low end and milage street 1500
G
With the 3.55 gear I figure it'd be nice to move some torque lower in the rev range. I never go above 5K and rarly do I go that high. Most cruising I do is 3000-4500 and I usually shift at 4k. I've been thinking about mods for a bit better milage and more low end torque, seeing I'm now loosing ~500 rpm at any given mph in 4th. I considred going from 30mm chokes to 28's but the car runs pretty good like it is.
I still have the 7.5 dish pistons in this engine. The head has been cut but I don't know by how much. So, I was thinking about a 1300 head with the smaller valves and ports. That should bump up my compression w/o having to cut the head and get special push rods. The smaller valves and ports should move my peak torque down lower and aid in better milage as well.
Peak cruise rpm should be around 4k and I'll probabaly still shift at that point. Most of the time I'll be at 2000-3500. Still considering the 28's with that head too.
Whatchallthink? Hap?
nomad
Does the 1500 head have the Westlake style combustion chamber? Assuming that it does I would go with flat tops to take advantage of the squish on the "Westlake promontory". Then I would change cams to one with a shorter intake duration. Higher compression and a shorter intake usually translate to better gas mileage. Read an article once on cutting a V shaped trench across the "promontory" aimed directly at the spark plug. Guy claimed great improvement in gas mileage because the engine would fire a much leaner mixture. Course he was offering the service for a fee so it may have been hockem!
Kurt.
G
Kurt, I'm looking at low budget, bolt on, finished in an afternoon modifications.
billspit
If you are going to use a Mk IV head, go ahead and do hardened valve seats, new guides, etc. You can also go with larger valves at that time. I seem to recall the MkIV head on a low compression 1500 gives a bit less than 10:1 CR. So it would work with 93 pump gas. Everybody says stay away from that head and high compression 1500 pistons as it seems to provide a CR of 10.5:1 or more.
G
Did any of the 1300 heads have hardened seats?
This is to hold me over for a little while till I can build the engine.
Scott_Hower
Nope. 1500 CA spec was the only head with hardened exhaust seats (TKC1410).
G
Never woulda guess that. So NONE of the other 1500 heads have 'em?
regularman
What rpm is high torque on the 1500? On the 1275 its 3000 rpm. Im running 65-70 at 3k in 5th gear. With a 4 speed you would probably be 60-65 at 3k.
G
Depends on the cam and carb. Mine should be ~2500-3K. What I'm seeing w/ the 3.90 500 RPM= 10 mph in 4th.
Morris
I have read somewhere (though I cannot site the source) that the 1500 in relatively stock trim makes max torque around 3500.
G
Depends on the trim. From the wiki:
"The home market's dual SU HS4 carbs were swapped for a single Zenith-Stromberg 150 CD4 unit, and the power fell to 50 bhp at 5000 RPM and 67 lb-ft of torque at 2500 RPM."
Found somewhere the euro was a bit higher in torque and RPM.
67 ft lbs, isn't that what the mains are torqued at?
IMO, and engine should put out more torque than is used to hold it together. :laugh:
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
D BT-7 tri-carb Two more questions Austin Healey 18
R TR2/3/3A One more crank pulley question Triumph 7
K TR2/3/3A More electrical....the Starter? Triumph 8
