MK2 upper radiator hose question
  • Thread starter Deleted member 8987
  • Start date
Deleted member 8987
I have a 2.4L RHD MK2.
The upper hose is quite old, and needs replacing.
The number is C21499.
I ordered one out of a good supplier I use regularly, with outlets in England, the US and Europe.
What I got doesn't fit anything on any MK2 I ever saw (smaller diameter by a bunch, and a 90 on one end).
Numerous discussions, they found the parts might have been mis-marked.
So, they sent me the correct unit.
This hose does not have the two ribs on it.
They claim (and I believe them) that the 2.4L did not have the ribs like the 3.4L and 3.8L did.
Any of you smart UK folks know for sure?
Everything I do is to "correct" 30+ years of gas station maintenance, so eventually it will be right.
I worked with the Jag Club of North America on an "appendix" to the Judging Guide on the MK2 to cover the many, many differences in a 2.4L version, and this may be another one.
Thanks.
Dave
Deleted member 8987
I just found out, there is some kind of Jaguar Master Parts Catalog or Viart Book and the guy with it says:
"the parts manual for the 3.4/3.8 lists C28972 for late cars, C27106 for middle and C 21499 for earlier cars and C 12424 for the first cars. C21499 is a straight hose w/o ribs and has a bend in it. "
My J.33 Parts Manual for my 1964 2.4L shows a C21499, which is a straight hose with a dip in the middle.
So, what I have is going on the car this week end.
PhilW
Is that 21499 hose a straight hose with a "bump" in the middle?
I have a whole box (somewhere) of factory Jag hoses with that shape, but they're marked C 21498. There's also a penciled number C 23801 on some. I've checked that number everywhere and found nothing. Maybe the factory mis-labeled them, missed by one.
Phil.
Deleted member 8987
Yeah, straight with a "bump" in the middle.
All I know is a guy in the Jag Club has this book with pictures next to the part numbers, and the C21499 is this one.
The last one they sent, though....MUST be real early.
Much smaler ID, not quite straight in the straight section, an a 90 on one end.....like a side outlet on the radiator or something.
Bigger than the bypass hose.
There is a number for earlier 2.4L, but it's in the book, out in the shop.
Don't know if they interchange or not.
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
H MK2 lover, but... what about an E type? Jaguar 5
Sopwith_Camel linkage jag mk2 Jaguar 1
Bristol401 For Sale Jaguar Mk2 Jaguar Classifieds 2
T Spitfire MK2 Generator Triumph 3
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
T Spitfire 67 MK2 Wiring Triumph 12
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
C Wanted triumph spitfire mk2-3 drivers seat bucket Triumph Classifieds 0
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
T MK2 vs 420 values Jaguar 20
A Austin Cambridge MK2 Other British Cars 2
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
I 1961&62 Mk2 sprite roofs Spridgets 1
I 61&62 mk2 roofs Austin Healey 2
D MK2 fuel system Jaguar 1
D MK2 rear springs Jaguar 3
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
LarryK Found MK2 parts in cavern. Jaguar 3
blurooster MK2 for wife Jaguar 21
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
M Healey Mk2 with Colored stock steering Wheel Austin Healey 3
D MK2 front motor mounts Jaguar 0
RickB Poor little MK2 Sprite - Seattle Craigslist 'Sebring bonnet' Spridgets 24
Sopwith_Camel mk2 parts left over Jaguar 4
S My dads 1962 Mk2 Austin Healy finally seeing light since 1981. Austin Healey 4
H MK2 Brake problems Jaguar 2
Lin Reinstalling rear springs and axle in 64 MK2 Jaguar 1
Lin Check Valve for Reservac Tank - MK2 Jaguar 3
M Spitfire Spitfire MK2 calipers Triumph 4
B going to look at a 61 mk2 Jaguar 5
AN5Sprite Jag Mk2..Deal or No Deal? Jaguar 12
D MK2 brake puzzlement Jaguar 15
C What are the differences in Midget MK2 and MK3 top Spridgets 6
L Spitfire 1965 Triumph Spitfire MK2 Triumph 4
longbridgehealey top bow mk 1 and mk2 sprite Spridgets 4
6 '65 MK2...typical "whats it worth ? " post Jaguar 4
J Brakes for a Mk2 Ford Cortina Other British Cars 4
D MK2 idler arm Jaguar 6
K Door Strikers and Latches MK2 Triumph 3
D MK2 rear axle "Bump Steer" Jaguar 4
D MK2 wiper motor Jaguar 4
D MK2 sandwich mounts Jaguar 3
D MK2 console armrest Jaguar 3
D MK2 rear shocks Jaguar 3
