milage range on Tank
KevinR
Member
Before realizeing the float from my fuel sender was no longer attached to the fuel sender I ran my BN7 out of fuel last week. I am asking for rough numbers but how many miles can you drive on a tank of fuel. I have a stock sized tank of 12 Gallons
This car ammazes my how well it goes down the road. the overdrive is a marvel you can hold a conversation while on the freeway. I have about 100 miles on a complete mechanical restoration.
Thanks for all of you advice
Kevin R
John Loftus
Kevin,
The best way is to calculate the MPG for your car over several fillups. (and a spare one gallon tank in the trunk is not a bad idea either!). Obviously, your milage will vary (sorry .. just had to write that!) depending on how you drive, city vs. freeway miles and mechanical variables of your particular car. I average about 18mpg with my BJ7 before the rebuild.
Cheers,
John
Dave Richards
While we're on the subject, how does one keep the nozzle from burbing fuel all over the paint??? It's very frustrating, but almost every one of my fill-ups accomplishes this! Dave
John Loftus
I don't recall having that problem here ... but in California we have a rubber bellows that goes around the nozzle to limit outgassing during filling. Do you have that type in NY? This seems to seal the filler pipe pretty well and the fuel cut off keeps from overfilling. I do try to keep a rag handy to wipe any errand drips.
Cheers,
John
K
KevinR
Member
After the first time I put fuel in this car at the station I had a fountain coming out of the fuel filler. The califrnia bellows at the greatest thing. I dont see them in the midwest and most fuel stations smell like raw fuel.
I am glad that I am not the first to spill all over the car
Kevin R
Velox
[ QUOTE ]
I have a stock sized tank of 12 Gallons.
[/ QUOTE ]
Hi Kevin, I believe the stock tank capacity is 14.4 gallons, which is what my replacement aluminum tank was listed as. Even with lousy mileage you should get 200-250 miles on a tank safely. Have fun! /ubbthreads/images/graemlins/cheers.gif /ubbthreads/images/graemlins/cheers.gif
Dave Richards
NO, we don't have the bellows like California, I remember those, we have something similar that I've trid to press down on the neck to no avail. I've thought about using paper towels from the dispensor, but when the gas gets on them, they're probaly classified as HazMat. Last fillup, I tried to figure out how much gas I needed to stop before the auto cut-off, but I needed less than I thought!
AndrewMawson
[ QUOTE ]
Kevin R
[/ QUOTE ]
I assume that to be 12 UK gallons, I think it is about 14 and a bit US ones. I get a generous 220 miles in my BJ8 to the tank full - long journeys can raise that to 250. I do however carry a one gallon tank in the boot 'just in case'
AWEM
Keoke
HI Kevin, /ubbthreads/images/graemlins/iagree.gif Figure on two hundred miles to be safe.---Keoke
Michael Oritt
[ QUOTE ]
how does one keep the nozzle from burbing fuel all over the paint??? Dave
[/ QUOTE ]
Dave--
To eliminate this problem get a 100.
John Loftus
[ QUOTE ]
[/ QUOTE ]
You'll get better gas milage too! /ubbthreads/images/graemlins/grin.gif
Dave Richards
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
Dave--
[/ QUOTE ]
/ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/lol.gif I'm working on it!
Michael Oritt
[ QUOTE ]
[/ QUOTE ]
Yes, and you can put the $$ savings toward the aluminum head that you will inevitably need.
David_K
I guess you gentlemen are using "city" MPG figures as if you mutiply 14.4 gallons x 26 mpg (Highway Factory Figure?) you should get over 350 miles per tank.
Keoke
---- /ubbthreads/images/graemlins/savewave.gif
----Keep on multiplying David and you can walk all the way back---Keoke- /ubbthreads/images/graemlins/lol.gif
David_K
I bet the figures are so low because the miles are mostly trips around the block. Might take some of you guys a year to accumulate 300 miles! /ubbthreads/images/graemlins/smile.gif
Dave Russell
Yoda - R.I.P
The reality is that unless you are driving 50 mph on flat land, most of the cars will get around 18 to 22 mpg. Since it is not particularly wise to completely drain the tank between fills, & some tanks don't like to be filled to the brim, a working capacity of 11 gallons is often used. This gives a realistic working range of 200 to 240 miles.
Keoke
[ QUOTE ]
[/ QUOTE ]
Would you believe 3000 or more.----Keoke- /ubbthreads/images/graemlins/driving.gif
G More low end and milage street 1500 Spridgets 11
G TR6 TR6 milage Triumph 14
D Fuel Milage Austin Healey 12
D MG MIDGET.....Bad Gas Milage Spridgets 22
D MG Midget Bad Gas Milage? MG 3
R BJ-7 gas milage Austin Healey 10
Aldwyn Gas Milage Triumph 30
jerrybny High milage Oil opinions Triumph 5
tahoe healey Healey Milage Austin Healey 8
S Wedge Gas Milage on Fuel Injected TR-7 Triumph 9
T Steering Wheel Adjustment Range Austin Healey 0
albertemore Range Rover Classic Parts? Rover / Land Rover 5
S Torque Range? Austin Healey 13
Steve Range Rover Evoque Convertible Rover / Land Rover 2
Boink First Range Rover Rover / Land Rover 2
Steve Range Rover Evoque Rover / Land Rover 1
M 2000 range rover????? Other British Cars 1
M Spark plug heat range Triumph 4
T Hi guys - can you help establish a date range? Triumph 2
T TR4/4A Date range for this TR4a engine Triumph 8
T Thermostat ugliness & temp range recommendation Spridgets 13
S TR2/3/3A TR3 hardtop.....price range and should I grab it? Triumph 11
texas_bugeye Spark plugs Heat range Ethl blended fuel Spridgets 6
tr7andtvr Range Rover Diesel Conversion? WVO Rover / Land Rover 1
T Temp. range for electric fan ? Triumph 23
W Upgrading to Range Rover Rover / Land Rover 1
VelodromeRacer Spark plug gap/heat range? Racing 8
L Power range of "hot" engine Austin Healey 7
tr7andtvr Wedge TR7 Range Rover Master Brake Cylinder Swap? Triumph 1
tr7andtvr Range Rover- TVR master cylinder swap? TVR 1
B Range Rover Electronic Fuel Injection Rover / Land Rover 0
tr7andtvr Range Rover Trade? Lotus 5
tr7andtvr Range Rover Trade? Rover / Land Rover 0
tr7andtvr Range Rover Trade? Triumph 0
tr7andtvr Range Rover Trade? TVR 0
philman range rover road trip Rover / Land Rover 1
sonuvagunsmith MGC Value range of an MGC MG 9
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
TomMull GT6 Gas Tank Outlet Triumph 0
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
B General MG 77 MIDGET Gas tank sending unit MG 1
BoyRacer Fuel Tank Sending Unit Austin Healey 3
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
