T-Series MGTD Factory Original Color
Foster
I'm currently restoring car no. TD/24613 and would like to determine its original color. It's now black, but when I first saw it in 1956 it was a badly faded tan / green (faded from the Texas sun). My body rebuilder asks whether I have a "Heritage certificate" - - never heard of it! Would appreciate any suggestions, beyond the general info from shop manuals and the "Color Schemes (TD & TF)" listed in Clausager, "Original MG T Series".
Cheers! - - Foster
Sarastro
Google "British Motor Industry Heritage Trust." You can get the certificate from them, and it will have all the information about the car's original color, equipment, and production dates. That's the gold standard for these things. I had one for my Sprite; dunno if I'll blow for it for the MG, though.
Platinum
The Certificate is a proper way to get documentation and good as a display item when the car is finished. :thumbsup:
The T-series cars with the tan/green scheme are really attractive, IMHO.
drooartz
I like the Heritage Certificates -- a neat way to verify what was original to your car. You need to go here:
https://www.heritage-motor-centre.c...d-archive-services/heritage-certificates.html
Unfortunately, as I look at the site it looks like they may only have them back to the MG TF (no TC or TD). You may want to email them directly and see if they can provide any more info. Your TD *might* have a certificate available as from what I've found they have records back to 1953. Worth a note to them asking.
I did pull this from the MG T register:
  • Chassis No: TD24613
  • Engine No: XPAG/TD2/24977
  • Build Date: 30-Jan-1953
  • Notes: TD24613 EXLNA
EXLNA just means export, LHD, North America. No note on original colors.
Sarastro
Dang, Drew, you're right--they just go back to '53.
In a sense though, this is liberating. If no one can document your car's oriignal color, you're completely free to make it whatever you wish, without any nagging concerns for originality.
Actually, like Doc E, I like the combination of green and beige. It's my favorite car combo. Very warm and handsome, and the two colors complement each other well, I think.
PAUL161
If the car has never been totally stripped, as in a frame off restro, it's possible the original color could be behind the running boards or fenders where they bolt to the tub. I found my TFs original color, (MG Red), behind the running boards, but no where else. PJ
One thing nice about TFs though, the original color is registered.
R T-Series Valve gap for an MGTD 1953. MG 5
B T-Series Battery replacement mgtd MG 2
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
PAUL161 T-Series Custom MGTD MG 5
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
A T-Series MGTD oil pump bypass valve MG 0
A T-Series Mgtd oil pump alterations MG 2
P T-Series Lea-Francis MGTD MG 10
P T-Series MGTD - before and after MG 3
H T-Series MGTD Christmas Ornament MG 1
vickxxx T-Series 1952 MGTD spark plugs. MG 4
bfitz T-Series 1951 MGTD oil pressure question MG 5
vickxxx T-Series turn signals for MGTD MG 5
smaceng T-Series Does a 1952 MGTD use a 12V battery? MG 4
richberman T-Series MGTD suicide door lock lever orders MG 0
B T-Series MGTD brake shoes. Are there leading and trailing shoes? MG 1
justin_mercier T-Series Dimensions of an MGTD windscreen? MG 1
S T-Series MGTD SEAT MG 1
rick_ingram T-Series Wanted To Find - MGTD #1091 MG 6
mountainman T-Series MGTD Top Insutlation MG 4
T MGTD -- Columbus Spotted 0
M T-Series soft plug 52 mgtd MG 3
mountainman T-Series MGTD What is it worth MG 2
G T-Series MGTD Steel wheels MG 3
B T-Series Pic of my MGTD MG 8
C T-Series Need a MGTD Steering Wheel MG 5
G T-Series Newbie '51 MGTD MG 2
P T-Series MGTD Fuel Pump Pressure MG 2
Steve P. T-Series Which Volvo engine fits in an MGTD? MG 40
Hedgehog T-Series MGTD sighting MG 3
P T-Series MGTD Front Brake Drum Removal? MG 9
CCURTISS T-Series MGTD/TF Carbon Release Bearing Question MG 3
CCURTISS T-Series Extra MGTD/TF Clutch Actuating Fork???? MG 2
J T-Series MGtd looking at one Sunday-need some help MG 4
T T-Series MGTD Supercharger MG 2
rick_ingram T-Series MGTD Crankshaft MG 6
6 T-Series MGTC / MGTD Period Correct Carb/Intake Systems MG 8
Steve P. T-Series any MGTD's with custom bodies out there? MG 7
W T-Series MGTD rear oil seal leak MG 7
G T-Series Dropping the oil pan on my MGTD MG 1
beaulieu T-Series MGTD engine/gearbox same as other MGs? MG 21
beachbumbarry T-Series MGTD anti-sway bar MG 4
EinsteinsDad T-Series MGTD Front suspension and Swivel / King pins MG 4
beachbumbarry T-Series MGTD basket case MG 16
T T-Series smiths or arnolt heater installation in an MGTD MG 1
martyc T-Series My MGTD-related Web Log MG 5
CARSINC How to remove factory contact cement? Spridgets 9
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
P For Sale MGA factory hardtop for sale. MG Classifieds 0
