T-Series MG A/B/TD/TF 5-speed tranny
MGA Steve
I remember that 6 months or so ago, there was a thread about overdrive conversions vs. 5-speed conversions for MGBs. Several responders indicated that 5-speed conversion prices were now too high to do that conversion.
Has anyone on the forum used the 5-speed conversion kit for the Ford Sierra transmission offered by Pierce Manifolds? You can view it on their Website at:
https://www.piercemanifolds.com/cylinderheads.htm
What were the results of your conversion--additional costs, problems, gear ratios vs. engine rpms, etc.? Is this the same kit offered by other vendors and how does its cost compare? /ubbthreads/images/graemlins/confused.gif
8NFord
Member
I am still undecided about Ford vs Nissan conversion. I plan to one or the other over the winter. I feel that the MGB OEM overdrive is ok, but it may be a bit problematic with the potential for electrics, hydraulics, and other lockout issues. I believe that we have two of the Nissan conversions in our local club cars. Only good reports that I know of. I feel the "B" needs that overdrive or 5th gear to drive at highway speeds. The Ford conversion is about $500 more than the Nissan and it is even better deaal if you can source your own Nissan trans.
frankenstang57
/ubbthreads/images/graemlins/tongue.gifI'll throw my 2 cents into this topic for what it's worth. Sorry if it's not the answer your looking for. By the looks of the Spitfire kit,(you're trying to swap into a MG tho, right?) the trickiest looking thing to come up with would be an adapter plate allowing you to bolt the trans to the bellhousing, and then getting the input shaft in the right depth. A competant machinist could do that. If it were me, I'd use a Ford 4cyl. T-5. Tons of them in the junkyards, and a pretty decent trans too. I see you live in Colorado, you should be able to find one easily at Pull-N-Save in Aurora for about $80.00. While you're at it grab the driveshaft from the donor. Use the front yoke from it & the slip yoke from the trans with the MG/Spit drivshaft. A driveline shop can put the two of them together to your length for around another $80. The rear mount is nothing but a piece of flat steel easily cut and drilled. I know I make it sound easy than it probably is but I've been doing wierd fabs like this for years. My buddy and I did a similar fab last spring when we mated a SBC to a 944 trans axle. It's no too terrible to do. How much do the sell these kits for anyway. Due to the fact you are local, I'd be more than happy to help you if need be.(that is between working on my $2005 Challenge car) Good luck!
BTW, when we did the Porsche, we used a Camero clutch disc with a 944 center piece. It's a custom piece, but a good shop could easily make one for you.
MGretired
Steve,
FWIW, I put in the pierce manifold 5 speed in my TD...GREAT! 1st class parts & instructions, well manufactured engine mounts...all in all, a very professional kit. VERY happy with the results.
MGA Steve
MGA Steve
Thanks, guys. All very helpful comments! /ubbthreads/images/graemlins/thumbsup.gif
mgamike
I installed a Ford Sierra 5 spd in my 58 mga. The kit from Quatum Mechanics in CT costs about $2000. It came with Rebuilt Tranny, bell housing, driveshaft,clutch disk, shifter. speedo cable, mounts & all hardware. I couldn't be happier. e-mail me MIKMEG @ aol.com if you want more info.
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
M Wanted dATSUN 5 SPEED TRANNY Austin Healey Classifieds 2
Jim_Gruber Is there a new 5 Speed Tranny Option available Spridgets 32
N Five speed tranny's!!!!! Spridgets 10
lbc_newbie Gear oil type for 210 4 speed tranny.... Spridgets 3
RickB 5 speed tranny = $867 shipped Spridgets 7
George Zeck 5 Speed Tranny ..... Spridgets 8
prb51 HVDA 5 speed tranny Triumph 18
77_MG_Midget 5 speed tranny conversion Spridgets 9
MGA Steve Spitfire Spitfire 1500 5-speed tranny conversion Triumph 0
George Zeck 5 Speed Tranny ...... Spridgets 44
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
PAUL161 Jag 5 speed? Jaguar 5
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
L General MG Five speed MG 6
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G 5-Speed Conversions Austin Healey 15
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
shadowfever Datsun 5-speed info neede Spridgets 5
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
PAUL161 T-Series 5 Speed Road Test MG 25
PAUL161 T-Series 5 Speed Transmission MG 85
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
crispy Idle Speed Variation Austin Healey 19
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
I GT6 A type OD vs D type - engagement speed? Triumph 3
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
roscoe 5 speed conversion question Austin Healey 9
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
Editor_Reid “Healey: Cars for Speed & Glamour” Exhibition Austin Healey 5
S TR2/3/3A Speed O not working Triumph 27
M TR6 5 speed conversion Triumph 33
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
