mastet cylinder leaks
healeydan12
I just put 1000 miles on my new combination clutch/brake
Master cylinder on my bug eye. It is pushing brake fluid out the vent hole in the cap
What is going on?
Billm
If you mean that you see a little squirt when you have the cap off and you release the clutch then that is correct- the fluid returns to the resevoir with some force.
BillM
H
healeydan12
BillM
No. I mean when the cap is on. There is so much pressure that it pushes fluid out the gasket. I tightened the screws and it stopped leaking there but it still comes out the cap vent hole.
jlaird
Wow, check for overfilling.
Gerard
Which aftermarket MC did you buy? I've rebuilt in the neighborhood of 300 originals and never encountered such an issue. Something's not right. You are certain you don't have a leaking fitting?
Deleted member 8987
Air.
You hit the pedal, you compress the air in the lines, let go, it expands quick and squirts fluid out.
Seen it.
Lots more than once.
Dave
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
L Removing Master Cylinder Without Paint Damage Austin Healey 27
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
W Cylinder compression Hillman super minx Other British Cars 15
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
Donald1107 TR2/3/3A low cylinder compression Triumph 12
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
S TR2/3/3A rear wheel cylinder Triumph 1
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
A Brake Master Cylinder Freeplay Austin Healey 11
SNClocks Master Cylinder Bore Diameter Spridgets 0
W replace rigid master cylinder lines with flex. Spridgets 2
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
6 Master Cylinder Actuator rods Spridgets 2
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
6 Master Cylinder Install Spridgets 5
Patrick67BJ8 Cylinder Compression Checks Austin Healey 30
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR6 Rear brake wheel cylinder fitment Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
