Looking for engine rebuilding 100-6
WestMichigan100-
I have all the equipment, micrometers, experience to rebuild the engine of my 1958 100-6.
Time is the problem.
I am looking for a shop that can do a rebuild closer to blueprint than just clean and reassemble with new wear and disposables. A shop that can break in the engine on a dyno.
There is a place in Colorado that do to this level but only 1930s vintage Cord, Rosenberg, Cadillac, and the like.
Any suggestions?
Thanks!
Reach out to members of the Southeast Michigan Austin Healey Club (Detroit area rep Ron Mitchel handles the email blasts; reach him at: rpmhealey@gmail.com ).
When I lived there__albeit, longer ago than I care to remember__there were engine builders, and hot-rod shops ALL OVER the Metropolitan area. Some may still be around...
I stopped dead from putting my name in the hat when you stated "Time is the problem;" and "A shop that can break in the engine on a dyno." I'm neither fast, nor do I have a dynamometer in my shop. But I do nice work...
Stepping up the game a bit here; BMW DOHC 4-valve/cyl with continuously variable cam timing. Full complement of polymer coatings applied (thermal barriers, thermal dispersants and dry-film lubricant). Being packed up for shipment to Livonia, MI where it was run in a local race series.
i.php
Same type of engine, a BMW S54 except this is a 3.4 ltr stroker (3.2 L stock) about to have its M Coupe body lowered over it.
i.php
Fresh rebuild of DOHC 4-valve/cyl BMW S52 engine with supercharger (single-step cam-timing on intake only).
i.php
TMS liked this picture of one of my engines enough to use it in their catalog for their "shorty" headers. This S52 was the first BMW engine that had a full complement of polymer coatings applied to it (at least the 1st BMW by me; I'd been applying them on LBC engines since the early 1990s).
Something completely different! An LS3/T54 Magnum for a BMW M3 (Bose Junge, or Nasty Boy in German!).
i.php
Another polymer coated S54 taking shape; fixture being used to install exhaust camshaft (they're hollow and can break if not pressed in__against valve spring pressure__evenly).
Michael Oritt
Though there is nothing that unique about a Healey engine that a competent engine builder/race shop could not handle you might want to contact Fourintune in Cedarsburg WI, as I believe they built and set up Larry Patterson's 100 race car/engine.
I must ask--why do you feel the engine would need to be "broken in" on a dyno?
LarryK
I don't know the name, but there is a restoration shop, I believe in Idaho, that does Austin Healeys and has the reputation of 100 point cars on every rebuild. They are on Barrett Jackson all the time, with $100,000 Healeys.
Editor_Reid
Platinum
I think you may be conflating two shops, but the only one I know of in Idaho is Lynn Martin's "Forever Healeys." Lynn's is a very-low volume operation of usually one car per year, and he works alone and has a waiting list. I really doubt you could hire him, but no reason not to try.
His cars don't show up at auction except rarely, so maybe you're thinking of a different shop.
Plus he's a restorer, not an engine specialist.
Close though, it's Iowa: https://www.healeywerks.com/
Let's see, 100 pt cars selling for >$100,000.00; probably not the most economical choice for an engine build. That said, probably looking at a range of $12k-$20k for a truly blueprinted and dyno tuned engine__to stock or near stock specs.
LarryK
That's the guy I was thinking about. When I restore a car it includes renewing engine. The whole car is done insitu.
bdcvg
Just call Tom at four-in-tune in Wisconsin and send it to His engine builder. Closer than Iowa and it was good enough for Bobby Rahal's 100m
bob hughes
Mmm did mine myself - farming the bits out to various firms, whilst the refurb was going on I visited a Healey specialist who farmed out an engine rebuild to an engineering firm and the engine was not cleaned out properly and needed refurbing again. The engineering company footed the bill but not sure if they carried out the work!
Point is you put a lot of trust into so called specialists and it could still go wrong.
:cheers:
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
W TR2/3/3A Engine rebuild - looking for preliminary advice Triumph 7
2billydavies TR2/3/3A looking for suggestions on putting engine back in Triumph 17
S Looking for a reputable engine rebuilder in Atlanta, GA area Austin Healey 6
J Looking for the right 4 cyl engine to produce 200 Racing 19
V TR2/3/3A Looking for 1954 TR2 engine Triumph 6
JeffS looking for PPG engine green paint code.... HELP! Austin Healey 9
AngliaGT Looking For a Saturn Engine Other Cars 4
C Looking for a 1500 engine Triumph 11
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
