Longbridge engine color
Aw c'mon Jim, show 'im a picture!
There was some controversy about what color this engine should actually be, as some of the earliest BN4s had a very dark green paint, but upon disassembly, traces of the widely accepted lighter green was proof-positive that this was the original color for the numbers matching car that Jim restored.
If you're interested in the build of this engine, I have pictures spread out in three (3) albums:
#1) https://spcarsplus.com/gallery3/index.php/LS_BN4
#2) https://spcarsplus.com/gallery3/index.php/LS_BN4_engine_build
#3) https://spcarsplus.com/gallery3/index.php/LS_BN4_engine_build/Final-push
After opening a thumbnail in each album, a second click on the opened picture will bring up the high resolution image, if you're looking for more detail.
DerekJ
It depends on when your Longbridge BN4 was actually built. From research I have done it appears that Morris Green engine paint first appeared when the 6 port head was introduced in November 1957. The paint continued until sometime in Jan/Feb 1958 before the light green metallic was re-introduced. I am not aware of any 'integral head' engines ever being painted Morris Green and the latest chassis/engine number for a Morris Green car that I am aware of is 56053.
C
ch47insp
I have yet to take delivery of my BN4 but I am interested in preserving the originallity when I work on it. Am I correct in thinking that the early BN4 engine color is the same as the BT7 engine color?
Great forum and thanks for your input.
George
C
ch47insp
I do not have access to the engine number as I have just received notice that the car is being picked up today and the previous owner could not find the engine number but I believe that it was built in the first couple of months in 1957. I should have more information in a week or so when the car arrives at it's new home.
Thanks
healeyblue
Well if it is the original engine then the engine number will be the same as the vin. Our engine number is 34099 and our VIN is BN4L - O - 34099.
healey106
I have a question about the color of the heat shield for the Longbridge cars. Per the 2016 Concours Guide, p 33 it states - "The heat shield was painted red (same color as the fan) and had no asbestos inner liner. The reason that the shield is a different color is that it could not be mounted until after the carbs were fitted. The heat shield covers the bottom securing bolts for the carbs. This is why it was not painted with the engine. This is also the reason that the heater tube is not green, as it was mounted after the carbs on the upper carburetors studs."
Has anyone found a red heat shield? my Longbridge from April 57 has a green heat shield and it looks like it has never, ever been red. What is the opinion of other Longbridge owners?
thanks:driving:
healey106
I should have read that earlier response, since I actually posted it from the 2015 Concours guide, which is what has been included in the 2016 Guide. I am now just trying to track down some Longbridge owners who actually have this red heat shield on their Longbridge. :driving:
DerekJ
I have never seen one. I'd like to see an original photo if one exists. The 100-Six brochure for the Longbridge 100-Six has a technical illustration of the engine. The fan guard is painted red but the heat shield isn't.
thanks:driving:
Well, it does not actually "cover up" the bottom studs, but you can certainly reach them easier without the heat shield in place. You can see the hi-res image from underneath here (click on the opened pic for maximum image size): https://spcarsplus.com/gallery3/var/albums/LS_BN4_engine_build/Final-push/IMG_1335.jpg?m=1316905154
Obviously these pictures are now old, as am I__and I've slept since they were taken__but if I had found any evidence on that particular heat shield that it was ever red, I would've questioned it. It must've still had been, or shown traces of green paint, so it was repainted green as was the engine. I have a pretty extensive library of Healey Marque books accumulated over the last four (4) decades, and I used everything that was available to me during the research of building that engine. Oh I wasn't concerned in the least about the mechanical stuff, that part's easy and second nature, but determining the finishes of the individual components was akin to participating in an archaeological dig; I was thoroughly invested and I enjoyed it.
The one obvious liberty__that nobody's ever mentioned, here at least__was that I was supplied with a Lucas Sports Coil, whereas a stock coil and bracket would've been engine color too, IIRC.
I think the biggest takeaway here, is that Albert, Bertrand, or Christopher (random guess at the factory worker's names) would've used whatever paints were closest to them at the time, it was just a workaday job for those blokes, never dreaming that someone in the distant future would even care. I know we've seen exceptions to accepted practices and finishes before.
Randy Forbes Longbridge Engine Number / Clarke Spares Owner Passed Away Austin Healey 5
andrea AH 100/6 1957 Longbridge Photo Albums Austin Healey 5
Csarneson Obscure Longbridge Parts Austin Healey 11
B Before and After Pics Longbridge 100-6 Austin Healey 5
B Side window question for early Longbridge BN4 Austin Healey 4
B Longbridge BN4 top frame question Austin Healey 6
B BN4 Longbridge door panel question Austin Healey 4
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
longbridgehealey BN4 Longbridge flasher unit. Austin Healey 19
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
healeyblue Longbridge side screen star shaped nuts Austin Healey 15
longbridgehealey Longbridge-built Healey Overdrive Switch Austin Healey 1
L Wanted 100/6 Longbridge hood parts Austin Healey Classifieds 3
D Photos of Longbridge BN4 door seal track. Austin Healey 5
R Longbridge Austin Healey Austin Healey 3
Csarneson BN4 Longbridge Fuel Tank Austin Healey 15
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
B Two Longbridge BN4 Questions - Indicator Light and Washer System Austin Healey 8
Csarneson BN4 Longbridge Oversized Valves? Austin Healey 5
longbridgehealey Longbridge built 100-6 dual washer nozzle Austin Healey 6
S BN4 Longbridge Question Austin Healey 6
John Turney Longbridge BN4 Soft Top Austin Healey 9
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
healeyblue The longbridge gets a hard top Austin Healey 17
T 100-6 Longbridge value Austin Healey 5
H Going to Hershey this week and anyone need anything for a Longbridge? Austin Healey 1
richberman Longbridge passenger lock chrome lever anyone? Austin Healey 8
5 Longbridge sidescreen vs hardtop Austin Healey 16
andrea LONGBRIDGE cars SOFT TOP -MOD safe water seapage Austin Healey 16
5 Longbridge BN4 exhaust Austin Healey 9
C BN4 Longbridge interior Austin Healey 86
5 Longbridge washer bottle Austin Healey 61
B 1957 BN4 Longbridge Austin Healey 2
richberman Anyone rebuild Longbridge washer pump Austin Healey 4
richberman Anyone have Longbridge side screen frames? Austin Healey 2
5 Longbridge screen washer button dimensions Austin Healey 8
coj Longbridge Sliding Top Austin Healey 13
H Early Longbridge BN4 Tool Bag Austin Healey 3
Barryp BN4 Longbridge / Abingdon feature combination??? Austin Healey 7
richberman List of bolts for 100/6 Longbridge Austin Healey 2
richberman Help in finding part: Longbridge hot air outlet Austin Healey 3
H Longbridge Radiator # ll B 2301 Austin Healey 3
5 Longbridge washer bottles on Ebay Austin Healey 3
W Longbridge 100-6 and adjustable steering wheel Austin Healey 7
richberman Longbridge BN4 hood slide assembly? Austin Healey 0
John Turney Longbridge BN4 Sidescreens Austin Healey 6
G Longbridge Factory Photos 2007-8 MG 0
N longbridge bn4 100/6 tonneau bar brackets Austin Healey 4
