Longbridge BN4 Sidescreens
John Turney
After getting the carpets wet last weekend at Morgan Hill, and taking most of the week to dry them out, I've decided that I need to spend some time with my sidescreens. So, two questions:
How thick is the Plexiglas/Perspex suppose to be (I never had the original)?
The nuts holding the sidescreens on the car are different for early BN4s than for all the other Healeys. The rear ones are available from the usual sources, but I haven't found a source for the front one, where the bracket goes through the hole in the top of the door. In fact, the usual sources don't even show it in their catalog pictures. They seem to be chromed unobtainium. I found one used one. Anyone know where I can get a second one?
ahealey1004
hi John- I took a measurement of a leftover piece from my old Longbridge bn4 sidecurtain plexiglass, which I assume is original. It measured just under 1/8" or 3mm thick. It's been a while but you can take old pieces as patterns to a glass shop and have them cut new plexiglass pieces for you. When I did it years ago, the stock they had available was a little thinner than original, so I had to shim them by installing some rubber strips to keep them from rattling in the aluminum frames. I suppose you could also use some modern silicone goo. Also installing a piece of that weatherstrip (the kind that looks like the soft-side of velcro) helped quiet them down and keep the draft out. If you need more measurements let me know.
Hope that helps.
Austin
B Side window question for early Longbridge BN4 Austin Healey 4
B Longbridge BN4 top frame question Austin Healey 6
B BN4 Longbridge door panel question Austin Healey 4
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
longbridgehealey BN4 Longbridge flasher unit. Austin Healey 19
D Photos of Longbridge BN4 door seal track. Austin Healey 5
Csarneson BN4 Longbridge Fuel Tank Austin Healey 15
B Two Longbridge BN4 Questions - Indicator Light and Washer System Austin Healey 8
Csarneson BN4 Longbridge Oversized Valves? Austin Healey 5
S BN4 Longbridge Question Austin Healey 6
John Turney Longbridge BN4 Soft Top Austin Healey 9
5 Longbridge BN4 exhaust Austin Healey 9
C BN4 Longbridge interior Austin Healey 86
B 1957 BN4 Longbridge Austin Healey 2
H Early Longbridge BN4 Tool Bag Austin Healey 3
Barryp BN4 Longbridge / Abingdon feature combination??? Austin Healey 7
richberman Longbridge BN4 hood slide assembly? Austin Healey 0
N longbridge bn4 100/6 tonneau bar brackets Austin Healey 4
longbridgehealey 100-6 BN4 longbridge mirror Austin Healey 4
longbridgehealey top frame for 100-6 BN4 Longbridge built Austin Healey 6
M Longbridge BN4 interior inner wheelwells Austin Healey 2
H BN4 2-Port Head Longbridge Registry Austin Healey 26
Randy Forbes Question about BN4 Longbridge vs Abingdon... Austin Healey 3
andrea AH 100/6 1957 Longbridge Photo Albums Austin Healey 5
Csarneson Obscure Longbridge Parts Austin Healey 11
B Before and After Pics Longbridge 100-6 Austin Healey 5
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
healeyblue Longbridge side screen star shaped nuts Austin Healey 15
longbridgehealey Longbridge-built Healey Overdrive Switch Austin Healey 1
L Wanted 100/6 Longbridge hood parts Austin Healey Classifieds 3
R Longbridge Austin Healey Austin Healey 3
C Longbridge engine color Austin Healey 16
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
longbridgehealey Longbridge built 100-6 dual washer nozzle Austin Healey 6
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
healeyblue The longbridge gets a hard top Austin Healey 17
T 100-6 Longbridge value Austin Healey 5
H Going to Hershey this week and anyone need anything for a Longbridge? Austin Healey 1
richberman Longbridge passenger lock chrome lever anyone? Austin Healey 8
5 Longbridge sidescreen vs hardtop Austin Healey 16
andrea LONGBRIDGE cars SOFT TOP -MOD safe water seapage Austin Healey 16
5 Longbridge washer bottle Austin Healey 61
richberman Anyone rebuild Longbridge washer pump Austin Healey 4
richberman Anyone have Longbridge side screen frames? Austin Healey 2
5 Longbridge screen washer button dimensions Austin Healey 8
coj Longbridge Sliding Top Austin Healey 13
Randy Forbes Longbridge Engine Number / Clarke Spares Owner Passed Away Austin Healey 5
richberman List of bolts for 100/6 Longbridge Austin Healey 2
