TR4/4A License Plate Protection
bammons
I need to get and put on a license plate on my car soon. The car has not been on the road in about 12 years and the plate was just bolted to the trunk. I live out away from everbody and don't have any cars to look at around so my question is; What are you guys using to lift the license plate frame off the paint? Rubber washers or something else. I just want a simple chrome frame but I want to best protect the paint. Bruce
B
bammons
Thanks Bob, that's what I figured but sometimes guys on here have unique and good ways to do things I would not think of so it doesn't hurt to ask. Just want to not damage paint. Anybody using the silicone frames? Bruce
Popeye
Bronze
I used felt; the kind you put under furniture. But a silicone frame is intriguing… what is that?
B
bammons
I have not had one in my hand but silicone things I have seen are soft and seem to be durable. I still would want it to be raised off the paint. But should be no fear of it damaging paint. Bruce
Popeye
Bronze
I use the felt with the idea that it breathes, and moisture can evaporate instead of being held against the paint. The mounting surface is vertical, so drainage is good.
Silicon buttons sounds like they would be effective as well, for example 3M Bumpon.
equiprx
I wouldn't want it to be anywhere near the body.
Everything underneath will affect the paint including the sun, air, moisture and debris.
Felt will capture the moisture for sure.
Why not fabricate a bumper mount?
Popeye
Bronze
You are correct - valid point thank you, and you have me rethinking my use of felt! (My main intent is to not scratch the paint. If the paint is intact, moisture is not a problem; most license plates are mounted vertically, so drainage is good.)
B
bammons
I opted to try (and ordered) a silicone frame but I will use a rubber or something spacer to lift it off the paint. Might try what BigGreen suggests. Bruce
Popeye
Bronze
One more thought… not to harp on the felt idea… but silicon does not “breathe”. Any trapped water will remain trapped. Make sure a silicon pad allows for drainage.
(I have changed my mind; silicon is the way to go. Correctly.)
B
bammons
A couple of you expressed interest in the silicone license plate holder mentioned above. I feel silly posting a picture of it being such a simple item but I got my new one in and I love it. Not what I started out to get but very happy with it. It is soft with a full back, and drain holes. You have to stretch it over the plate. I added nylon spacers between it and the car (not noticeable) and thinner ones on the inside of the trunk with wing nuts for easy removal if I want to clean under the plate. If the silicone touches the paint I am confident no harm is done. And I like the minimalist look. Did I mention it was cheap $8? Thanks for the advice everyone. Bruce
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
I TR6 License plate lamp Triumph 7
AngliaGT What Goes Here? - Holes Behind Rear License Plate Mount Spridgets 3
R Wanted License plate light Triumph Classifieds 0
I TR6 Source for license plate light bracket? Triumph 5
S License plate light - inline fuse, BJ8 Austin Healey 7
J Wanted TR6 Chrome Front License Plate Holder Triumph Classifieds 0
T TR4/4A License plate on trunk lid Triumph 6
Marvin Gruber Mounting info needed for late BJ8 license plate holder Austin Healey 9
T TR2/3/3A rear license plate bulb number Triumph 4
5 Legacey California License Plate Spridgets 1
Rut License plate holder Spridgets 1
I TR6 Rear license plate gasket Triumph 2
Jim_Gruber What is this for, 3 holes + 1 Large hole on rear License Plate Indent on BE Spridgets 17
bigjones Ever re-paint your license plate? Spridgets 22
jaegzie What is the piece called between license Plate lamp and body. Can't find in catalog Spridgets 10
DanLewis California License Plate "BUGS EYE" For Sale [NFI] Spridgets 0
R Rear license plate bracket Austin Healey 26
N TR4/4A TR4A license plate light wiring Triumph 5
T TR2/3/3A TR3 front license plate Triumph 4
5 Rear license plate shroud holes location Austin Healey 4
P 1959 license plate wanted Triumph 8
J TR2/3/3A license Plate Lamp mounting on TR3A Triumph 2
D license plate lights, trunk and 3rd stoplight out Jaguar 4
H TR4/4A License Plate Bulb Holder On TR4 Triumph 6
J How do you mount the rear license plate on a BE? Spridgets 10
J Bugeye license plate light plinth Spridgets 10
memphis Rear License Plate Lighting Austin Healey 2
memphis License Plate [rear] Mounting Location? Austin Healey 12
I Bugeye license plate lamp wire help Spridgets 4
Monark192 Front License Plate Bracket? MG 8
bighealeysource License plate light problem on BJ8 Austin Healey 4
R TR6 '71 TR6 License Plate Light Housing Triumph 7
E license plate bracket Triumph 5
ModifiedBJ7 Rear License Plate & Lighting Austin Healey 3
Tinkerman TR2/3/3A TR-3 License Plate Lamp Triumph 2
R MGB Poor grounding license plate lamps 67 MGB MG 13
R BJ7 License plate & lamp mount points. Austin Healey 2
jjbunn License plate light options Triumph 18
SCguy TR4/4A TR4 license plate bracket location Triumph 11
Creatrixx License plate mount/bracket? British Motor Corp 7
Bruce_B Ways to mount front License plate on BE Spridgets 11
toysrrus "INTERNATIONAL" License Plate Mania: Where are You Triumph 0
toysrrus License Plate Mania; Send Pics Triumph 69
bcliff Help decoding a british license plate Triumph 7
David_K License plate lamp glass Austin Healey 4
T Spitfire Check out this Spitfire [look at license plate] Triumph 18
