TR6 Rear license plate gasket
ichthos
Finally have my rear license plate light installed. Does the cover go over the gasket lip or inside it? It does not seem to fit well either way. Thanks,
Kevin
trrdster2000
Kevin, Inside the lip if the early one on the bumper. They sure are proud of those gaskets, got a few from Rimmers' years ago when they had a sale. Be sure to put the grommet on the panel in the car, water gets in there quickly.
Wayne
AngliaGT What Goes Here? - Holes Behind Rear License Plate Mount Spridgets 3
T TR2/3/3A rear license plate bulb number Triumph 4
Jim_Gruber What is this for, 3 holes + 1 Large hole on rear License Plate Indent on BE Spridgets 17
R Rear license plate bracket Austin Healey 26
5 Rear license plate shroud holes location Austin Healey 4
J How do you mount the rear license plate on a BE? Spridgets 10
memphis Rear License Plate Lighting Austin Healey 2
memphis License Plate [rear] Mounting Location? Austin Healey 12
ModifiedBJ7 Rear License Plate & Lighting Austin Healey 3
P Rear license plate Austin Healey 9
R TR6 rear license light parts Triumph 0
tahoe healey rear license late mounting. Austin Healey 11
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
