TR4/4A key cylinders
shoopal
Does anyone know how to get the cylinders out of the ignition switch, door,trunk and glove box locks?
CJD
When you turn the key to the on positions, there is a button on the back side that becomes exposed. You press the button while pulling the key outward.
S
shoopal
I don't have the keys which is why I want to jigger the pins or make a key. I'm going to try to pick them.
CJD
I was in that boat. Check out post #15:
https://www.britishcarforum.com/bcf/showthread.php?96249-Lock-Help-you-out-there-JP
You will have to pick the first lock. From that one you can hand cut a key blank...and with any luck, the other locks will still match a single key.
These are rickety locks, so picking them is not all that hard. You need one small blade screw driver to place a continuous twist on the cylinder. While holding that force, you need a little dental pick to run in and out, pushing the tumblers. With persistence you should be able to pop it in a minute or 2.
You must get them to turn in order to get them apart.
Tr-Beg
When I bought my tr4a the trunk was locked and no key received, With 2 little shafts it was possible to open the trunk in 2-3 minutes, hopefully rickety locks indeed.
J Ignition Key Malfunction Austin Healey 6
PAUL161 T-Series MGTF Ignition Key MG 7
J Coach Key (T-Key / Chruch Key / Fool's Key) Revival Restoration & Tools 0
KVH General Tech Oil Pump Woodruff Key Triumph 10
D Key Blanks Austin Healey 6
M TR6 Key Codes Triumph 7
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
6 1965 Sprite Ignition Key Spridgets 3
R Woodruff key for DWR camshaft? Austin Healey 2
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
K Correct key head shape. Austin Healey 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
S TR4/4A Ignition switch key position Triumph 2
TomMull TR2/3/3A Wee coach key Triumph 2
CJD TR2/3/3A Original Style Coach Key? Triumph 24
G Generator - Key Replacement Austin Healey 6
S Open a ingnition key barrel to find the key number. Restoration & Tools 2
S key ID from a barrel? Other British Cars 5
Rut RX7 key fob Spridgets 6
Scotsman TR4/4A Commission Plate interpretation "key" Triumph 3
Got_All_4 TR2/3/3A Ingnition switch key change Triumph 7
5 ignition-trunklatch key Austin Healey 3
W TR6 TR6 Horn only works when key is off Triumph 27
M TR4/4A Trunk/Boot lock key code?? Triumph 4
F Sunbeam/Hillman Key Blank Sunbeam (Rootes) 4
H Spitfire Triumph starts just fine but Ignition is 'Off' and key is in my wife's purse. Triumph 6
S TR2/3/3A small woodruff key Triumph 5
W Bugeye ignition key repalcement Spridgets 2
S TR2/3/3A timing chain cover and woodruff key Triumph 4
D Start Bugeye with KEY only - OR - KEY plus light switch on S or H? Spridgets 4
pkmh BJ8 - Removal of existing Key Washer behind castellated nut Austin Healey 20
J TR2/3/3A Ignition key issue Triumph 4
JPSmit Wiring Key - hand to have Restoration & Tools 1
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
PatGalvin TR5/TR250 TR250 Ignition Key Question Triumph 4
S TR6 TR6 project back together- turn the key and CLICK Triumph 7
M 99 XJ8 How Do You Troubleshoot Key Transponder Module? Jaguar 0
M X-308 99 XJ8 Engine ECU and Chip in Key Jaguar 2
K TR2/3/3A TR3 Dzus Key Fob? Triumph 4
M T16 engine, ecu and two key fobs, or Rover 820 Rover / Land Rover 0
TonyPanchot Spitfire 72 Spit 1500 Key Light Triumph 2
K TR2/3/3A TR3..testing wiring..leaving key on..Petronix? Triumph 3
V Door lock key cylinder Triumph 9
G MGB MGB "Spare" key MG 7
