Woodruff key for DWR camshaft?
robcadle
Member
Hope someone here has a quick answer for me. I bought a DWR8 cam from Denis Welch Racing and am in the process of installing it. The woodruff key does not appear to be the same as the factory one. The slot measures ~0.192” deep versus ~0.232” factory. The key diameter also appears to be smaller. The new cam kit did not come with a new key, so I’m a bit stuck. Hoping someone here has dealt with this before so I can get a new key now without having to wait until Monday to call DWR.
Thanks in advance,
Rob Cadle
steveg
My DWR8 cam required an offset key (vs a one-time use of DW's pricey vernier arrangement). Russ Thompson sourced it.
I wouldn't be inclined to trust a hardware store key available on a Saturday - sounds like your impatience is pushing you.
KVH General Tech Oil Pump Woodruff Key Triumph 10
S TR2/3/3A small woodruff key Triumph 5
S TR2/3/3A timing chain cover and woodruff key Triumph 4
davidk More on Crankshaft woodruff key Triumph 3
Simon TR4a Woodruff key stuck [generator] Triumph 5
T TR4/4A Early TR4 - Crank Pulley Woodruff Key Triumph 7
J Ignition Key Malfunction Austin Healey 6
PAUL161 T-Series MGTF Ignition Key MG 7
J Coach Key (T-Key / Chruch Key / Fool's Key) Revival Restoration & Tools 0
D Key Blanks Austin Healey 6
M TR6 Key Codes Triumph 7
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
6 1965 Sprite Ignition Key Spridgets 3
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
K Correct key head shape. Austin Healey 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
S TR4/4A key cylinders Triumph 6
S TR4/4A Ignition switch key position Triumph 2
TomMull TR2/3/3A Wee coach key Triumph 2
CJD TR2/3/3A Original Style Coach Key? Triumph 24
G Generator - Key Replacement Austin Healey 6
S Open a ingnition key barrel to find the key number. Restoration & Tools 2
S key ID from a barrel? Other British Cars 5
Rut RX7 key fob Spridgets 6
Scotsman TR4/4A Commission Plate interpretation "key" Triumph 3
Got_All_4 TR2/3/3A Ingnition switch key change Triumph 7
5 ignition-trunklatch key Austin Healey 3
W TR6 TR6 Horn only works when key is off Triumph 27
M TR4/4A Trunk/Boot lock key code?? Triumph 4
F Sunbeam/Hillman Key Blank Sunbeam (Rootes) 4
H Spitfire Triumph starts just fine but Ignition is 'Off' and key is in my wife's purse. Triumph 6
W Bugeye ignition key repalcement Spridgets 2
D Start Bugeye with KEY only - OR - KEY plus light switch on S or H? Spridgets 4
pkmh BJ8 - Removal of existing Key Washer behind castellated nut Austin Healey 20
J TR2/3/3A Ignition key issue Triumph 4
JPSmit Wiring Key - hand to have Restoration & Tools 1
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
PatGalvin TR5/TR250 TR250 Ignition Key Question Triumph 4
S TR6 TR6 project back together- turn the key and CLICK Triumph 7
M 99 XJ8 How Do You Troubleshoot Key Transponder Module? Jaguar 0
M X-308 99 XJ8 Engine ECU and Chip in Key Jaguar 2
K TR2/3/3A TR3 Dzus Key Fob? Triumph 4
M T16 engine, ecu and two key fobs, or Rover 820 Rover / Land Rover 0
TonyPanchot Spitfire 72 Spit 1500 Key Light Triumph 2
