TR6 Key Codes
Marmoset54
Member
Morning, fellas!
Just got my email back from the British Motor Heritage Trust…
And I got some key codes.
Anyone to contact for getting these made? Missing trunk, door, and glove box keys.
Thanks!!!
bammons
A full service locksmith can do it also. My keys were missing after 11 years of disassembly and a move and my codes seemed to be all different so I elected to take them to to Ricks Lock and Key in Chattanooga. Hopefully they will key them all alike but at least get me down to two keys as original. Have not picked them up so don't know the cost yet. Bruce
sp53
I have purchased many key from Pete Groh. He is a great guy to deal with, I gave him the code on the face of ignition lock and he sends out the key. If the door handles are off or if the trunk handle is off, the key codes are on the side of the shaft of the handle on tr2, tr3 and tr4.
steve
HelenBr
I was wondering if a locksmith in west norwood service would be able to help you out? Any other locksmith service, I have mentioned West Norwood just because I've used this service for a couple of times. I think a locksmith service is that what you are looking for
S TR2/3/3A tr3 key codes Triumph 11
J Ignition Key Malfunction Austin Healey 6
PAUL161 T-Series MGTF Ignition Key MG 7
J Coach Key (T-Key / Chruch Key / Fool's Key) Revival Restoration & Tools 0
KVH General Tech Oil Pump Woodruff Key Triumph 10
D Key Blanks Austin Healey 6
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
6 1965 Sprite Ignition Key Spridgets 3
R Woodruff key for DWR camshaft? Austin Healey 2
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
K Correct key head shape. Austin Healey 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
S TR4/4A key cylinders Triumph 6
S TR4/4A Ignition switch key position Triumph 2
TomMull TR2/3/3A Wee coach key Triumph 2
CJD TR2/3/3A Original Style Coach Key? Triumph 24
G Generator - Key Replacement Austin Healey 6
S Open a ingnition key barrel to find the key number. Restoration & Tools 2
S key ID from a barrel? Other British Cars 5
Rut RX7 key fob Spridgets 6
Scotsman TR4/4A Commission Plate interpretation "key" Triumph 3
Got_All_4 TR2/3/3A Ingnition switch key change Triumph 7
5 ignition-trunklatch key Austin Healey 3
W TR6 TR6 Horn only works when key is off Triumph 27
M TR4/4A Trunk/Boot lock key code?? Triumph 4
F Sunbeam/Hillman Key Blank Sunbeam (Rootes) 4
H Spitfire Triumph starts just fine but Ignition is 'Off' and key is in my wife's purse. Triumph 6
S TR2/3/3A small woodruff key Triumph 5
W Bugeye ignition key repalcement Spridgets 2
S TR2/3/3A timing chain cover and woodruff key Triumph 4
D Start Bugeye with KEY only - OR - KEY plus light switch on S or H? Spridgets 4
pkmh BJ8 - Removal of existing Key Washer behind castellated nut Austin Healey 20
J TR2/3/3A Ignition key issue Triumph 4
JPSmit Wiring Key - hand to have Restoration & Tools 1
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
PatGalvin TR5/TR250 TR250 Ignition Key Question Triumph 4
S TR6 TR6 project back together- turn the key and CLICK Triumph 7
M 99 XJ8 How Do You Troubleshoot Key Transponder Module? Jaguar 0
M X-308 99 XJ8 Engine ECU and Chip in Key Jaguar 2
K TR2/3/3A TR3 Dzus Key Fob? Triumph 4
M T16 engine, ecu and two key fobs, or Rover 820 Rover / Land Rover 0
TonyPanchot Spitfire 72 Spit 1500 Key Light Triumph 2
K TR2/3/3A TR3..testing wiring..leaving key on..Petronix? Triumph 3
V Door lock key cylinder Triumph 9
