TR2/3/3A Just Discovered These Alternator Conversion Anyone Do One
Got_All_4
Years ago I was going to do a alternator conversion in my TR3. However I wanted to keep that original look and kept me from doing it. I was looking for something on Ebay and came across this set up. Any one do this? I would want to keep the original Voltage regulator in tacked too and run everything thru it but I'm sure it would have to be gutted since it has it's own internal regulator. A little on the pricey side too but seems very easy install. I emailed the seller if the original pulley will fit on it but no reply in the last 3 days.
https://www.ebay.com/itm/Generator-...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
TR4nut
I did the same on my TR4 - no long trips yet but it was an easy fit. Mixed reviews on the longevity of these setups so I keep a stock regulator in the boot and can go back to a generator if needed.
Got_All_4
Got_All_4
Is that a real bearing in the back plate or a bushing like the originals? Also does it pull the air from the back or the front for cooling?
dklawson
Those alternators have been available for more than a decade. Thankfully their price has dropped a lot since their introduction. When first introduced the products had a reputation for short lives with heat blamed for the failures. Hopefully longer life can be expected from the current products.
If you want to retain the original loom you certainly can buy the dummy box offered by BPNW (linked above). However, if you have a dead generator control box, those can be converted by most home mechanics using instructions you can download from the Mini Mania website. However, to take full advantage of the added output of the alternator you should also consider adding a second 10 AWG brown wire from the alternator to the hot terminal on the starter solenoid.
Got_All_4
Got_All_4
Just got a message that this generator does not fit the original pulley. However SASSAMON said his original pulley and fan fit fine. Are there different alts out there?
Rhodyspit75
Not knocking the supplier, but mine gave me fits. The first one was not drilled deep enough for the tach drive to fit. The second one the tach drive threads weren’t cut properly so my original tach drive wouldn’t thread on. The supplier sold me an alternator pulley and fan. The pulley was smaller than the original so the tach wouldn’t read right. I was able to get a fan and pulley from a friend and then that didn’t line up properly. Once i shimmed the pulley and carefully chased the threads everything finally works.
This is was on my Bugeye so hopefully you won’t have the same problems.
Got_All_4
Got_All_4
At lease for now I'm not willing to change the main pulley and water pump pulley. Added expense and for me but the worst is the extra time it will take to change over and source the parts. It would have been great to have a bit more piece of mind. Had to change one out 3 times at the TRF Summer Party weekend once. I do have a brand new Lucas generator that I carry for a spare when I go on trips. Might just for now keep doing what I'm doing.
TR4nut
I’m not sure what brand the BPNW is but it was a fit to the original pulley and an easy install. If you aren’t in a hurry you could wait for one of their decent sales and get a better price.
HealeyRick Operation CIA Healey Discovered? Austin Healey 5
C TR6 New rust discovered Triumph 10
Trevor Jessie I discovered a new "talent" today Spridgets 5
Sherlock Discovered today Spotted 10
M Discovered the Remains of a Bugeye Today Spridgets 2
Steve Another stash discovered! Other British Cars 5
Sherlock A Harrington Coupe discovered Sunbeam (Rootes) 3
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
PAUL161 T-Series Dynamator Alternator conversion. MG 23
P '58 XK150 Dynalite Alternator swap question Jaguar 5
B Delayed charging Lucas alternator Triumph 1
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
Walter74 Dynamo to alternator Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
donbmw TR2/3/3A Converted to alternator Triumph 14
90dog A H Spares Alternator Bracket Austin Healey 53
R TR2/3/3A generator to alternator Triumph 5
JPSmit Alternator help - please. Spridgets 21
I Bugeye generator/alternator conversion question Spridgets 7
Ripper01 TR6 110A Alternator Triumph 7
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
Sopwith_Camel alternator eater Spridgets 20
longbridgehealey Alternator conversion and tach Austin Healey 9
