TR6 Issue of the day......restart and idle after shut down
poolboy
A couple of things to consider in CJD's post.
Because the float level is normally set with the carb upside down with the float tab resting on the needle valve, lowering the float, say from 17 mm to 15 mm actually increases the level of fuel in the float chamber...17mm, btw is my recommendation.
Also, If it's percolation, and not an extremely low float level (high fuel level) or otherwise too rich a mixture, the percolation starts at the very bottom of the float chamber causing the fuel to percolate up the jet which is open about as low in the float chamber as possible and still pick up fuel.
Think of the old Maxwell House coffee commercial..blip, blip....blip blip blip blip.
Here's a picture of the jet, illustrating the depth of the jet in the float chamber. It's actually down in the depths of the float chamber plug's cavity.
The cure for percolation is protecting the fuel in the float chamber from the heat of the exhaust system.
TomMull
Going along with John's (CJD) second post suggesting a rich mixture, I'll give my parallel experience (albeit SU H6 carbs on a TR3). I had the same issue for weeks last summer. I finally rebuilt the jets and choke mechanisms for a different problem, reset the mixture and the problem went away completely. (I had added an Alexander heat shield prior to rebuilding with little improvement.)
Tom
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
T 100 BN2 Possible Ignition Issue Austin Healey 10
B MGA Tach drive issue MG 1
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
J Issue with Reverse Spridgets 2
Celtic 77 MGB Seized air pump issue MG 25
H TR4/4A Advise asked on TR 4 a frame collision/issue Triumph 20
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
B General MG Turn Signal Issue MG 1
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
K TR2/3/3A Brake issue? Triumph 8
M TR6 Alternator Issue for 72 TR6 Triumph 7
A TR6 TR6 Distributor cap issue Triumph 4
EricJNewman MGB Weird Brake issue finally solved. MG 1
B Any issue with cutting this weld on the spring base plates? Spridgets 4
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
C TR2/3/3A Water pump issue Triumph 8
Guido36 Chassis Number Issue Austin Healey 11
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
mch979 1967 MGB GT bonnet issue MG 25
H T-Series Brake Issue MG 5
K TR2/3/3A Steering Issue? Triumph 23
P TR3B Coil Issue? Triumph 7
Lin Excellent Issue of the Marque Magazine Austin Healey 2
R TR6 Is this a starter issue? Triumph 6
M Lighting issue Austin Healey 3
B TR4/4A Thrust washer issue Triumph 11
jfarris Honda Parts Issue? Other Cars 1
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
M Heat-related carb issue on BN1 Austin Healey 7
M TR6 Starter lagging issue Triumph 2
M TR6 PDWA Issue Triumph 5
R Issue with odometer after repair Austin Healey 1
Michael Oritt Bulb holder issue Austin Healey 5
D TR4/4A rebound stop clearance issue Triumph 13
S BJ8 Overdrive Issue Austin Healey 7
Michael Oritt Brake issue Austin Healey 24
G MGB Starter and fuel issue MG 6
S BJ8 Overdrive issue Austin Healey 10
M Help with 60 Bugeye - major drivetrain issue... Spridgets 78
catfood Looking for suggestions - ignition issue Austin Healey 6
N Electrical issue. FORUM Navigation Questions 2
Lin Another trafficator issue Austin Healey 8
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
glemon General Tech Turn Signal Issue Triumph 12
Michael Oritt Speedometer drive issue Austin Healey 4
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
S TR2/3/3A Electrical Issue Triumph 40
F TR6 Frame Issue Triumph 11
