Is there a Cruise Control for Spridgets?
twas_brillig
Anyone have or have knowledge of a cruise control for a Spridget? I've done a search on the site for the last year or so but no luck; I understand that there used to be a motorcycle aftermarket cruise control that might have been adaptable but is no longer available. I'm curious for both the Spridgets as well as old air-cooled VW Beetles.
Thanks,
Doug
Billm
I did a hand-control lock on mine but it was less than satisfactory when one is convoying. I have a couple of old "after-market" ones that I want to try but haven't gotten to it yet.
If I recall correctly Dave Lieb in Chicago (or was it Glen burns) did one using the coil as the speed sensor that worked well. I will try to replicate that work.
BillM
leecreek
Get up with Spritenut. He had a real nice one at the Lake of the Ozarks.
The audiovox units work ok if you add a vacuum reservoir.
I used a rostra unit that is controlled with an electronic servo. I mounted mine under the dash so that the only thing extra under the hood is the cable running to the carb.
JPSmit
Not a Midget but I knew someone who installed his in his Sunbeam Tiger - switches were in the ashtray which I always thought was cool. Likely you could find something in the various hot rod magazines
The Rostra unit is the one that is popular with the Street Rod. Also sold as Dakota Digital.
spritenut
Mine came from Audiovox and works great.
It even cancels when I step on the clutch as it has an impulse from the tach.
I did not use the magnets on the driveshaft either.
Simple, around $100, and the switches are mounted on the radio console right where my fingers can touch them as I drive with my hand on the shift knob most of the time anyway.
I did get the vacuum reserve which was extra and other than following the directions, the only modification I made was to the carb heat shield to attach the cable. So now my carb shield has 2 cables, the original throttle and next to it, the cruise control cable. I had to make a 2 cable cable end for the gas and cruise cables but that was just some grinding and drilling to a 1/4" bolt to accept both cables.
And on the open Interstate from Jersey to Missouri I got 42 mpg and my engine is not stock :smile:
I bought mine from Amazon.com 2 years ago.
T
twas_brillig
Spritenut: Amazon lists an Audiovox Ultracruise II 250-1316 Electronic Cruise Speed Control Kit for $ 200; I also had a look at the Audiovox Internet site and they don't list cruise controls.
Is this the same model as you installed? We're running a side draft Weber - can you see any problems with that?
Thanks,
Doug
HAN8L1965
Yeah my 6'2 frame and foot wedged up against the tunnel on the right side and my left knee crammed under the window winder on the other.
Mark
spritenut
Audiovox CCS-100 is my cruise unit.
$89 2 years ago plus the vacuum ball which is the size of a large orange was another few bucks.
regularman
I'm not a fan of cruise control but when I lived in the desert I put one on a old mustang two. It came from JC whitey and would fit any car. It was really an engine rpm control, but for a straight drive its the same thing when locked in high gear. I put a similar one on the wifes festiva. Its still on there but she don't use it much. Make sure you get the adjustable gain kind.
T
twas_brillig
Trevor - can you advise as to which Rostra you installed, and if there were any additional bits/options that you used?
Thanks,
Doug
250-1223 and 250-3592
I have an electronic speedo in my car and I used the speed signal from it. I do not know if you can run it just off the tach. It is highly configurable for gain, and surge, etc.
Lin Cruise control on an overdrive Healey Austin Healey 4
HealeyPassion Cruise Control Austin Healey 0
D loss of cruise control Jaguar 2
Lin Installing the Audiovox Cruise Control Unit Austin Healey 0
Lin Cruise control Austin Healey 1
DanNagy Cruise Control/Foot Rest Triumph 30
T Cruise Control Triumph 12
M XJS V12 Cruise Control Jaguar 3
JPSmit Tonight's cruise night Spridgets 6
JPSmit Tonight's cruise night Other Cars 18
Sherlock Another cruise night, more interesting British iron Spotted 2
Sherlock Car cruise night Spotted 6
Bob Claffie Best cruise in of the year Spotted 8
Lotus Club SoCal LCoSC - Petersen Breakfast Club Cruise-In Lotus 0
S Cruise Night - 2017 Spridgets 19
B Thoughts...rough running at cruise. Austin Healey 3
S Cruise Night! Spridgets 20
Bob Claffie General MG Hemmings Motor Cruise MG 3
JPSmit Cruise Night tonight - not pretty but interesting Other Cars 8
J Auburn, CA Cruise Night Austin Healey 10
kodanja TR6 Spring Time to Cruise in New England~!!! Triumph 0
aeronca65t First Cruise - Super 7 Other British Cars 9
J Went To Auburn Cruise Night and met an Aussie who just bought a 54 to take back home. Austin Healey 1
JPSmit Cruise Night last Night Spotted 5
Bob Claffie Hemmings monthly cruise-in MG 0
B Cruise night..FINALLY AN MG!!! MG 4
MY66AH Great times on Cruise to the Woods Spridgets 2
JPSmit Cruise Nite Wednesday Spotted 5
aeronca65t Cruise night-Chatterbox [NJ] Spotted 1
JPSmit Cruise Night tonight Spridgets 4
Nelson My first cruise-in Spridgets 4
JPSmit First Cruise Night tonight Spridgets 1
JPSmit Cruise Night last night Spotted 1
jvandyke Grand Rapids Metro Cruise? Spridgets 0
regularman Took a nice cruise today. Spridgets 21
Brosky Great cruise day in RI Triumph 8
Brosky 35 mile shake down cruise Triumph 20
DNK Wedge TR8 Shake down cruise Triumph 11
D Long Island NY British Car Sunset Cruise 7/19 MG 1
H Me & Sprite at the Milford Cruise In [I drove it!] Spridgets 20
EMGEBE MG Cruise Pics MG 13
A Just out for a Cruise MG 10
EMGEBE Young nutters cruise Other Cars 2
EMGEBE MGB 42nd MGB Birthday Cruise MG 1
donbmw Global Cruise Triumph 2
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
KVH General Tech Heater control valve/cable Triumph 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
