Hello Lin, I have never done it, but you can configure your electrical system anyway you want it. but I believe there are a few questions about how you want it to be operateable. At first I thought it would be a good idea to make it to stay engaged only when the car is in 4th gear. That way if you come out of OD it would stay engaged. But I don't think that is a good idea. It would probably scream the rpms if it stayed engaged upon coming out of OD. So then I think it should only be allowed to stay engaged when the car is in OD. That way when you come out of OD, the cruise would drop out and you would be in normal 4th gear with no overriding system on your accelerator.
The way I think I would do that is that you can replace your dash mounted OD switch with one that looks just like it but has two separate sides, or electrical paths thru it. It would have four terminals on the back, two on top and two on the bottom. And each side is separate. It is called a Double Pole, Single Throw Toggle Switch (DPST). Each side opens and closes at the same time as the other side. Like a double knife switch you might have seen on an old clothes dryer or water heater system, but it is in the size of a toggle switch. So with that switch, one half you feed to the OD and one half would feed to the cruise control. When you flip it off, they both go off. Since both halfs of the switch are completely separate, you can run power to it from two separate sources or fuses. Or if you think the fuse and wire that is feeding the OD is strong enough to also handle the crusie control amps, you can energize this switch with the original OD power wire and then put a little jumper across the 2 top terminals. I would recommend two separate sources from 2 separate fuses. Well just thinking out loud, that's my 2 cents. Dave.
PS. I'm editing my original post here because the idea of running the cruise off the same switch as the OD is correct but not completely sorted out. If you did it the way I discribed above, the cruise control would engage anytime the OD was engaged.
But my correction would be to still wire it as above but the wire for the cruise control coming off the DPST switch would then have an engagement switch for the Cruise Control. This then would still drop out the cruise control everytime you took it out of OD.
