Intake / exhaust manifold gasket install goop?
GeorgeC
I am installing a new intake/exhaust manifold gasket. I've got Ultra Copper, should I put in on both sides? Gasket is fiber on both sides.
59 Bugeye
Thanks
Joe Schlosser
I have never used any sort of sealant on the manifold gaskets. Multiple builds and blownb head gaskets on FP car never had any leaks with a dry gasket.
Lots of copper spray on head gasket though.
Platinum
Copper spray for head gaskets, appropriate torque on the fasteners with dry gaskets for the intake/exhaust. Same experience as Joe. E-Prod, C-Sedan and MANY street (performance Lotus and BMC) mills.
...maybe a film of oil on the intake/exhaust gasket if fiber. With a re-torque after initial heat sink run of the engine. Never had a problem either way.
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
C TR2/3/3A Intake/Exhaust Manifold Replacement Triumph 11
J New tube exhaust and intake manifold Austin Healey 15
J TR2/3/3A leak proofing intake/exhaust manifold Triumph 20
doughairfield Intake/exhaust manifold gaskets Triumph 1
bcbug removing exhaust/intake manifold Spridgets 6
2wrench Opinion on intake and exhaust manifold studs Triumph 5
MGTF1250Dave TR2/3/3A TR3 Intake Exhaust Manifold Studs Triumph 9
B Intake/Exhaust Manifold Gasket Triumph 3
Brosky Intake and exhaust manifold powder coating Triumph 18
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Healey Nut Intake/Exhaust gasket Austin Healey 3
H intake and exhaust question Austin Healey 4
dklawson MGB MGB Intake/Exhaust Needed - [re-posting] MG 7
mgedit TR2/3/3A 56 TR3 Intake and Exhaust Manifolds Triumph 8
dklawson 1500 Intake/Exhaust Gasket - Siamese Ports? Triumph 10
R installing Intake Exhaust mainfold Triumph 18
N Which way for intake exhaust gasket? Triumph 1
W Replacing Exhaust/Intake gaskets and studs. Triumph 2
VelodromeRacer Exhaust/intake gasket Spridgets 6
C Exhaust/Intake gasket sealer? Austin Healey 4
Brosky Studs for intake/exhaust manifolds Triumph 2
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Intake header crossover passage..... Triumph 4
K TR2/3/3A Failed intake manifold gasket? Triumph 2
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
shadowfever MGB MGB intake wanted MG 2
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale- TR-6 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale TR6 '69-72 Intake Manifold Stanpart V3108 Triumph Classifieds 0
steveg TR6 Fixing the intake manifold Triumph 8
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Michael Oritt Intake manifold question Austin Healey 11
steve00136 MGB Intake manifold alignment MG 4
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
Lin Intake manifold drain pipes Austin Healey 29
R FFuel overflowing at Intake Manifold Austin Healey 10
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
P For Sale Weber carb/intake, header Spridgets Classified 2
