Intake/Exhaust Manifold Gasket
bcouz
Hi All,
I posted this inthe wrong section before and I appreciate the responses. Let me try to do it right.
My '71 TR-6 keeps blowing out the intake/exhaust gasket. I have a header, which I know make a differencde. Is there a heavy duty gasket for this application? One response recommended a copper spray on the gasket. What is that? I appreciate your help. I'm new here and I really like the communication.
Alan_Myers
Hi,
I know there are heavy duty (thicker) gaskets available for the 4-cyl. Triumphs, would have to assume that someone (Moss Motors, Victoria British, The Roadster Factory, British Parts Northwest, British Frame and Engine, Goodparts, etc., etc., etc.) sells one for the 6-cyl. cars, too. Keep looking.
However, a thicker gasket generally isn't necessary.
First, you mention a header and that might be part of the problem. Often headers need some "fine tuning" for a good fit. This is because they are essentially handmade, plus welding can cause some warpage as it cools. Often some milling of the headers manifold face is needed, to make it as flat as possible or to adjust a little for a particular car. Some headers just fit better than others, sort of depending upon the manufacturer. And, there can be other factors. One header I installed on a TR4 couldn't be tightened at all because it had a thinner flange than the stock exhaust manifold and lacked spacers at most of the hold-down points, to make it flush with the intake manifold. Once some spacers were welded onto it, it could be pulled up nice and tight. You might want to check with a local shop that does header installations to see if any of this sort of work is needed on your car.
You might be able to spot some of these problems yourself, if one or more of the fasteners seem to tighten up first, while there appear to still be gaps. If you are using a torque wrench to tighten, it might also be as simple as a bunged up thread on a mounting stud or a bad nut that appears to tighten, but really isn't.
Unlikely, but possible, is that there is some fault in the face of the head itself, at the exhaust ports, causing a small leak that eventually turns into a big leak. Worth checking carefully, but I doubt you'll find anything. The mating faces of the head and the manifold each need to be nice and clean, too.
One problem with some heads happens if they are milled to increase compression. This is usually only when a lot of milling is done, that repositions the gasket and manifolds so that some obstruction causes some interference. For example, I know the top edge of the block of the 4-cyl. TR engine needs to be chamfered a bit, to increase clearance, if the head is milled more than .120-.150" or so. If that's not done, the block will usually interfere with the manifold gaskets. I don't know whether or not this might happen with the 6-cyl. head, but it's easy to check and correct if need be.
Close inspection of all these areas, threads, etc. might find the problem. Use a straight edge on the face of the header and the head too look for interferences and/or if either is warped in any way.
Also, if the exhaust system puts a lot of strain on the header, that might be part of the problem. A clue to this is if you have to really lever or force the parts together during assembly because they don't align well, or even if engine torque strains the system while driving (a flex joint installed close behind the header might solve this latter problem). The continual stresses can eventually cause leaks, or even worse, can crack mounting studs or the manifolds themselves.
Permatex, for one, makes a copper gasket sealant that's available in spray, brush-on cans, and squeeze tubes. In this sort of application, spray on is likely the best to get a nice, even coating. Most any local auto parts store will have this sealer.
Hope this helps. Keep us posted!
B
bcouz
Thanks for the tips, Alan (with confirmation from DNK?). I think I may eventually mill the header. In the mean time, I bought the Copper Gasket Sealant and sprayed both sides of the gasket, the block and the header. I'll start re-assembling tonight.
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
C TR2/3/3A Intake/Exhaust Manifold Replacement Triumph 11
J New tube exhaust and intake manifold Austin Healey 15
J TR2/3/3A leak proofing intake/exhaust manifold Triumph 20
doughairfield Intake/exhaust manifold gaskets Triumph 1
bcbug removing exhaust/intake manifold Spridgets 6
2wrench Opinion on intake and exhaust manifold studs Triumph 5
MGTF1250Dave TR2/3/3A TR3 Intake Exhaust Manifold Studs Triumph 9
Brosky Intake and exhaust manifold powder coating Triumph 18
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Healey Nut Intake/Exhaust gasket Austin Healey 3
H intake and exhaust question Austin Healey 4
dklawson MGB MGB Intake/Exhaust Needed - [re-posting] MG 7
mgedit TR2/3/3A 56 TR3 Intake and Exhaust Manifolds Triumph 8
dklawson 1500 Intake/Exhaust Gasket - Siamese Ports? Triumph 10
R installing Intake Exhaust mainfold Triumph 18
N Which way for intake exhaust gasket? Triumph 1
W Replacing Exhaust/Intake gaskets and studs. Triumph 2
VelodromeRacer Exhaust/intake gasket Spridgets 6
C Exhaust/Intake gasket sealer? Austin Healey 4
Brosky Studs for intake/exhaust manifolds Triumph 2
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Intake header crossover passage..... Triumph 4
K TR2/3/3A Failed intake manifold gasket? Triumph 2
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
shadowfever MGB MGB intake wanted MG 2
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale- TR-6 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale TR6 '69-72 Intake Manifold Stanpart V3108 Triumph Classifieds 0
steveg TR6 Fixing the intake manifold Triumph 8
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Michael Oritt Intake manifold question Austin Healey 11
steve00136 MGB Intake manifold alignment MG 4
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
Lin Intake manifold drain pipes Austin Healey 29
R FFuel overflowing at Intake Manifold Austin Healey 10
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
P For Sale Weber carb/intake, header Spridgets Classified 2
