Which way for intake exhaust gasket?
Norton47
On a 74 TR6 which way does the intake exhaust gasket go when one surface has metal and the other gasket material or does it make a difference.
I installed mine with the metal surface to the head.
Is this ok?
G
The metal surface faces the manifolds. You have it backwards, but who's to say it won't work?
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
Healey Nut Intake/Exhaust gasket Austin Healey 3
dklawson 1500 Intake/Exhaust Gasket - Siamese Ports? Triumph 10
VelodromeRacer Exhaust/intake gasket Spridgets 6
B Intake/Exhaust Manifold Gasket Triumph 3
C Exhaust/Intake gasket sealer? Austin Healey 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
C TR2/3/3A Intake/Exhaust Manifold Replacement Triumph 11
J New tube exhaust and intake manifold Austin Healey 15
J TR2/3/3A leak proofing intake/exhaust manifold Triumph 20
H intake and exhaust question Austin Healey 4
dklawson MGB MGB Intake/Exhaust Needed - [re-posting] MG 7
mgedit TR2/3/3A 56 TR3 Intake and Exhaust Manifolds Triumph 8
doughairfield Intake/exhaust manifold gaskets Triumph 1
bcbug removing exhaust/intake manifold Spridgets 6
R installing Intake Exhaust mainfold Triumph 18
W Replacing Exhaust/Intake gaskets and studs. Triumph 2
2wrench Opinion on intake and exhaust manifold studs Triumph 5
MGTF1250Dave TR2/3/3A TR3 Intake Exhaust Manifold Studs Triumph 9
Brosky Studs for intake/exhaust manifolds Triumph 2
Brosky Intake and exhaust manifold powder coating Triumph 18
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Intake header crossover passage..... Triumph 4
K TR2/3/3A Failed intake manifold gasket? Triumph 2
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
shadowfever MGB MGB intake wanted MG 2
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale- TR-6 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale TR6 '69-72 Intake Manifold Stanpart V3108 Triumph Classifieds 0
steveg TR6 Fixing the intake manifold Triumph 8
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Michael Oritt Intake manifold question Austin Healey 11
steve00136 MGB Intake manifold alignment MG 4
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
Lin Intake manifold drain pipes Austin Healey 29
R FFuel overflowing at Intake Manifold Austin Healey 10
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
P For Sale Weber carb/intake, header Spridgets Classified 2
