Ignition Wire Set
gonzo
Any recommendations a good source for a set of quality ignition wires for AH3000 MKII? Is it possible to locate similar sets from local parts suppliers like NAPA? I’d like to avoid assembly of the spark plug terminal end – never had any luck with crimping the leads.
Another option is to use the Bumblebee period-type performance set. But with advancements made in the past 40 years the upgraded performance of these wires may just be cosmetic. Anyway, I’ve seen more of these sets on MGs and Triumphs, rarely on a Healey. Does anyone have experience running the Bumblebee wires on their Healey?
Opinions welcomed…GONZO
PeterC
Bosch make a good set of solid core wires with angled ends on the spark plug end, yet unassembled on the cap end. 7mm gray silicon jacketed. Bosch number for 6 cyl set 09986 (4-cyl is 09985, and 8-cyl is 09987)
Peter C.
Ed_K
I used a set of Napa 700173 stranded wire 7mm 6cyl semi-custom made by Belden. They have the spark plug connectors and boots already molded on. Just cut the distributor cap ends of the wires to the desired length and shove them into the holes of the side entry distributor cap and tighten.
Darwin Spitfire ignition wire gauge Triumph 2
T Ignition wire bursts into flames Triumph 12
I Bugeye ignition coil wire help Spridgets 7
T Ignition switch wire Triumph 3
W Ignition wire Spridgets 2
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 7
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
S Ignition advance weights - how to lube? Austin Healey 5
K TR2/3/3A Ignition Timing? Triumph 11
