Ignition wire bursts into flames
T
Tinster
I had to replace a broken choke cable set when the 2 fires happened. First time, I did not touch any wire. Everything running fine. I removed the 2 screws that hold my small dash to the frame and angled the tiny dash forward to gain access to the choke cable set-nut behind the dash. Installed the choke cables, angled the tiny dash back into position and the hot wire from the ignition switch all the way to the PowerBlock Hot-hub exploded in flames and smoke and melted. Yes, ditz had battery connected.
Second attempt: Disconnected battery, same procedure, rotated small dash downward but not off frame. Installed new ignition hot wire, rotated small dash back up. Touched red battery cable to battery. Yellow primary ignition hot wire blew up in flames and smoke again. I am stumped. Any help appreciated. The primary wire is unfused.
Andrew Mace
First thought is that you have a pinched wire or something else causing a major short circuit / power-to-ground connection. I've been through similar situations on a TR250, where everything behind the dash seems to be in very close quarters!
T
Tinster
Yes Art, had to be a major short and it was. Full power of battery directly into the dash steel frame behind the ign. switch. Both fires melted the copper primary ignition wire. I just a bit ago found the cause. I figured the full power of the battery was needed to melt a No8 copper wire that fast. I slowly reversed my procedure. BINGO. In the upright position, the Hot terminal of my ignition switch just grazes the dash steel frame. Major short. Easy fix- rotate the key switch 30 degrees.
TomMull
Sorry, missed last post. This is of course moot. Glad you found it. Tom Agreed. I'd put in yet another wire and check for continuity between that wire and frame (or any ground) with an ohm meter. There should be none (ignition off and battery disconnected). Follow to each connection until you find the short. It will most likely be close by. Tom
KVH
Dale, is that your TR6 in the Photo? Dash looks nice. Is that the same TR you were having so much trouble with, or a different one?
T
Tinster
Yup same car. Thanks on the dash- I designed it and had it cut from Puerto Rico native Teak. It took me 4 years to restore the '69 TR6 to reliable running condition. Been having fun driving it for over a year without a break down.
d
startech47
Dale,
I glad the damage was so localized. I little wire can make a lot of smoke. I had visions of the garage at knee height after the fire was extinguished. Happy motoring.
TonyPanchot
I have found that a good wrap with electrical tape on all terminals in close prox to the metal dash frame is a good measure IMHO
T
Tinster
Houston- We have lifttoff" !! HooRah HooRay. Dashboard wiring harness repaired, new, twin Stromberg choke cables installed -
The ancient old bucket of bolts '69 Triumph TR6 Amos started on very first crank of the key. YEEHAW!!!
Many thanks to all who contributed advice, including Dan masters.
Terminals either wrapped or liquid plastic. And yes, the primary ignition wire melted due to a short will certainly 1/2 fill a garage with smoke. I did it twice.
Amos humming away in the garage during this monsoon rain day.
14dna
Dale;
You look good in that car!
Happy Motoring!
Dave :driving:
71MKIV
:thumbsup: :thumbsup:
Darwin Spitfire ignition wire gauge Triumph 2
I Bugeye ignition coil wire help Spridgets 7
T Ignition switch wire Triumph 3
W Ignition wire Spridgets 2
G Ignition Wire Set Austin Healey 2
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 7
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
S Ignition advance weights - how to lube? Austin Healey 5
K TR2/3/3A Ignition Timing? Triumph 11
