Ignition parts quality
kozelding
So my Healey's been on jackstands for almost two weeks, as I've tried to find time to deal with low overdrive pressure. Saturday I went to run it one last time to make sure everything was adjusted before putting back the tunnel and interior.... And, crap, after 10 seconds, it started running HORRIBLY. I couldn't believe it -- sputtering, backfiring, I could barely get it above 2500 RPM.
After furious troubleshooting, the problem turned out to be: a bad condenser.
I've read online folks complaining about bad ignition part quality, but this was first I've witnessed it. That condenser had barely 4000 miles on it! Plus, I've never known a bad condenser to cause such trouble -- it's just that thing you replace with the points 'cause it's cheap and easy.
Anyway, end of rant. At least now I know to make sure a condenser is always in my emergency parts bag.
Gearhead_Garage
Install a Pertronix and be done with points and condenser. Put black heat shrink over the two wires and you can barely tell the difference externally. I have Pertronix in 3 cars now, including a vintage race car. Works great, no worries.
MikeP
The thing with a condenser is they can last forever, or fail in 5 minutes. They have a small floating paper disc to serve as an insulator in them and holes can develop. I had one once that would run fine, then rough then fine and so on. The insulator had a small hole burn in it and when that hole lined up right would short internally. As said, moving away from pre electronic components will solve that, but can bring on issues of their own, nothing is 100% failure proof..
Keoke
:iagree:-----------:applause:
steveg
Agree with the Pertronix users. I've been using Pertronix for 10 years and fried a couple of them, too. Now I'm using the ignitor as well as Pertronix' non-ballasted coil. Had a no-name coil go bad before and fry the pertronix. I've also fried them trying to test the spark or leaving the ignition on with the motor off for a couple of minutes. The biggest danger to the Pertronix are mis-handling during tuneup and incorrect polarity.
Using the condenser, you should carry maybe 4 of the tested spares from Advanced Distributor, as well as a spare coil. Today's condensers are all cheaply made in China with the possible exception of the Standard, which is made in Mexico. Use the red rotor design from Advanced or Moss. Some of the older rotors especially the ones with the brass rivet are unreliable.
pan
Electronic versus original ignition is a hot topic here at the moment. On my side (original) we know that if trouble should occur far from home there is always a way to get mobile again if the appropriate spares are on hand. The biggest problem seems to be poor quality after-market parts. Genuine Lucas parts are preferable!
Wood touching is definitely happening here at the moment!
Electronic versus original ignition is a hot topic here at the moment. On my side (original) we know that if trouble should occur far from home there is always a way to get mobile again if the appropriate spares are on hand. ...
Pertronix aren't THAT expensive. I installed mine with quick-connect spade connectors; I can swap out my Pertronix as fast, if not faster, than you can install points and adjust them (and heaven forbid you drop one of the tiny washers on the points). Unfortunately, in my case my Pertronix is old and they've made a slight change in the mounting meaning I'd have to ballpark the timing if I have to install the new one.
steveg
NOS Lucas would be good if you find any. The new parts labelled 'Lucas' these days consist of regular Chinese stuff with all their faults (according to my source at Moss).
FWIW, On trips I carry a spare DM6 distributor with gapped points as well as spare condensers and rotors. My disty has bullet and eye connectors and a wiring diagram so it can be setup on anyone's non-BJ8. I index the base plate to the block with a tick mark so each distributor can be swapped out (on my car at least) without adjusting the timing.
Keoke
The older rotors especially the ones with the brass rivet are unreliable.
This is because the rivet reduces the dielectric path length between the spark and the grounded dizzy shaft.
The repeated arching along this path virtually creates a direct short to ground.
What I have done in the past was,Drill out the rivet in a new rotor and fill the void with JB weld. That seemed to work very well.
Keoke
Well BOB, that depends on where you are located. Here in the US they are cost effective. In the UK you will need a second job to afford one :highly_amused:
IN OS I do not know but It may be a bit expensive there too.
I understand there is an equivalent--'Spark' something-or-other--that is available in the UK and quite affordable.
healeymanjim
in our british car club we have folks with and without electronic ignition. some have had good luck with them and others not so good. two friends with a morgan and mgb pulled their petronix and replaced with normal ignition and have not had any problems since. i have concluded there is more to hooking up and electronic ignition than just sticking it in and hoping it will work ok. possible something to do with positive ground, but not sure. i am staying away from electronic ignitions. have limped home mores than a few times with old system and always carry spares.
Duncan M
I would definitely get pertronix for any vintage racing car. Getting one because of bad luck with a condenser is a bit out there. A lucas MGB condenser will work on almost anything, if you are that hard up. When I do a tune up I always buy a new condenser when I buy points, but do not install the condenser unless the one in there is suspect. I've been using the same condenser for a LONG time. When you switch to pertronix you need to replace your points coil with an overpriced one. No thanks. I knowa lotof people get pertronix because their car is eating points. Rather than re-bush their distributor, they get pertronix and wait until the whole thing wobbles its way out of the engine and goes into orbit. Not a good tactic. They are good for racing cars because they allow for easier starting, and allow higher rev's than a points setup.
Keoke
NO That is a misconception:
The pertronix is an excellent upgrade for these old LBC.
Simplicity of installation is achieved using negative ground.
However, both sets of installation instructions are easily followed.
Pertronix is quite happy tooling along on an original lucas sport coil.
Modern versions are smaller and do not arc from the tower.
However, the hotter the coil the more fire you put in the hole.
... Pertronix is quite happy tooling along on an original lucas sport coil.
Yup. Been running with that setup for many moons and miles. Lucas Sport Coils are known to have quality issues (unless they've been rectified).
Edit: I misread this; my Pertronix has been running for many years on a STOCK Lucas coil. The Sports Coils are known to have problems (from a trusted source); but quality may have improved.
steveg
I'm running a Pertronix non-ballast coil after having qc issues with the Lucas sport coil. Jeff at Advanced Distributors recommends Bosch Big Blue Coils - evidently they are filled with resin as opposed to the others filled with oil.
John Turney
I've been using a Crane electronic ignition and Lucas sports coil for 15 years with no problems. I recently added a Crane optical trigger to my speedometer cable to run a tripmeter.
Keoke
Yeah Steve that is a good coil you use to be able to find them in older Volvos in the junk yard a they were stock ignitio items.
vette Ignition Parts Frustration Austin Healey 18
nevets BN6 ignition parts question Austin Healey 3
Ed_K New and used ignition parts for sale. Austin Healey 0
T Ignition parts question Triumph 23
aeronca65t antique ignition parts Restoration & Tools 0
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 9
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
S Ignition advance weights - how to lube? Austin Healey 5
K TR2/3/3A Ignition Timing? Triumph 11
