TR6 I have Webers in my TR6 - now looking for SUs
TRnorwegian
Bought the car last year with the carbs already rebuilt.
I don't think they will add any performance as long as nothing else was done to the power packet. And I'm not planning to start any major upgrades.
I'm not trained to tune Webers myself, and good help is hard to come by where I live (Norway). A friend suggested I change back to original carbs, and it sounds like a good idea.
Or what do you guys think? Any interest in buying my Webers? Any ideas where I should look for SUs?
Rgds, Anders from Oslo
tdskip
Why not stock ZS? They work pretty well if they are in good shape, and they are easy to rebuild and tune. Certainly easier to rebuild and tune than the SUs (not that SU's aren't great).
NickMorgan
Have you asked on the UK TR Register Forum? I would imagine that there may be some people on there who would be keen to have your Webers and there could be others who have taken carbs off their American import to fit fuel injection. Didn't the TR6 use Strombergs?
LBCs_since_1988
I had 1 3/4 SUs in my old 1973 TR6. One VERY nice upgrade by a previous owner. NOT a DPO in this case :thumbsup:
TRnorwegian
TRnorwegian
You're quite right. Standard spec is Strombergs, and that's what I'm looking for. Your UK connection idea sounds logic. To me it's also much closer.
Thanks y'all.
Anders - Up North
DNK
If you want your Webs' tuned. Find an independant Ferrari mech.
They'll do it
Tabcon
I have 2 ZS's listed on Ebay right now that I removed from my engine prior to ripping it to pieces.
I have a reserve on them of $250, but it looks like I won't be getting it by tomorrow.
The carbs have been rebushed and rebuilt and worked fine on my TR4, but I'm now putting 2 Weber 45DCOE's on it due to the many performance upgrades I've made to the engine.
I don't know if these are the same carbs a TR6 uses and I'm sure the intake won't work for you, but it they're interchangeable, maybe we could work a trade.
Let me know.
DNK
I used a guy in Md for my Downdraft on my Capri.
He was great, kinda of full of himself though.
I bet if you Wiki a Ferrari mechanic it probably list that.
Platinum
:iagree:
A triple Weber setup (DCOE's, NOT those poxy downdraught thingies!) is LOADS better than a ZedS setup. Tune 'em ONCE and drive forever. No diaphragms to rupture, an honest set of accelerator pumps built in, BEARINGS instead of bushings for the shafts... The suggestion of finding a knowledgeable Ferrari wrench makes a lot of sense if ya don't want to have a go yourself.
I will ~assume~ them to be 40mm. 45's would be a bit of overkill... but will work just fine if jetted and choked correctly for the application.
Have you looked at the plugs to see if it even NEEDS to be fiddled with? Some "plug cuts" would be a good First Step in deciding if something needs looking into.
tdskip
Uh oh, here we go.... LOL.
Makes sense to try and tune them before throwing in the towel - heck, they are already on the car.
Anders - is there a local TR club in town?
kodanja
I put dgv's on mine 3 years ago after rejetting them and havent had to touch them since'
my performance increased 110% over my old stock strom's
I had the Stroms set up on my 73' GT6 & they were GREAT~!
Trip DCOE's may be a completely different animal thou....
TRnorwegian
TRnorwegian
Thanks to you all for good advice. I,m wiser, but not necessarily more confident with regards to which option is the better.
I've tried having the Webers tuned, and I may even find someone with more expertise down the coast, a couple of hours away. (Since my personal Ferrari mechanic is constantly busy working on all my vintage Ferraris.)
Even so, these DCOE 40s has a reputation of backfiring, well deserved I might add, since the engine caught fire 4 times during two weeks in June. Last time the car nearly went up in flames. Been in the worshop since then.
So my confidence in this set up has deteriated. But guess what?
I just traced the Stromberg dual carbs belonging to my car to the guy who modified it to Webers (2 owners down). They're sitting on his garage floor in Florida, and he'll sell them to me for $ 150, including the original intake manifold.
He advise me to buy a rebuilding kit for both carburetors, because they
have sat idle for more than 3 years. He knows carburetor rebuild kit sold for $74.95 per carburetor.
Does it matter which rebuild kit I use?
Rgds,
Anders in Oslo
Platinum
Frying pan to fire!!
Usually Webers spit back 'cause they're too rich. The FIRE was 'cause the timing is off somehow.
DNK
I'd say it's running a little rich if the carbs are catching fire. I don 'r know enough about that style to say the "float" is to high.
Platinum
Idle jets, most likely... and TIMING.
jessebogan
Probably good to have the strombergs.... But. Like Doc said, if possible, use the DCOEs. The engine has to be RIGHT. Valves adjusted correctly, timing spot on (to the cars needs, NOT the US emission control sticker) Try 10 degrees BTDC at idle, and around 32 to 36 degrees BTDC at 3000 RPM. Then, get down to adjusting the webers. There are some good books on the subject, but I cannot put my fingers on the one I am thinking of at the moment. I *think* it might have been a Haynes manual of all things. It had charts showing emulsion tubes arranged from rich to lean, and so on. (The numbers on them are no help that way, they seem to have been numbered at random...) The jets numbers do increase as more fuel or air flows.You would do well to find someone that does this work already, so that maybe you can swap jets, emulsion tubes etc, instead of having to shell out cash for 6 of everything. However, once done, there is nothing like a correctly set up set of webers. We used to call them the "pipe organ" both because of the looks, and the sound. The other thing that enters my mind, it to look at airboxes on cars equipped with webers from the factory. They are usually substantial, not just cheezy filters stuck to the carb mouths. Fabricating something more like that, with a remotely mounted filter might cure the fire danger. Also, CARRY A FIRE EXTINGUSHER IN YOUR CHERISHED CAR AT ALL TIMES!!!!.
boxofparts
Very nice set up.. Another option is to look for Volvo SU carbs considering your location. I think the P1800s had HS6s that would fit with the standard Triumph manifold.
Weber vs. ZS vs. SU ... I would take the SU for the simplicity of the carb.
Simmo TR6 Triple Webers on TR6 Triumph 7
hondo402000 TR6 TR6 40 DCOE Webers Jets needed to borrow them Triumph 3
hondo402000 TR6 TR6 Dialing in my Webers DCOE Triumph 2
boxofparts TR6 Tr6 Down Draft Webers - need help Triumph 2
Guido36 Webers on a Healey 100 Austin Healey 6
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
F TR6 Carburetor issues at low rpms webers Triumph 23
S Hard starting on Webers from cold Austin Healey 12
J Triple Webers Austin Healey 19
B Spark plugs with Webers Austin Healey 6
hondo402000 Tuning my Webers now Triumph 13
sparkydave Webers don't like backfires Spridgets 1
TRnorwegian I'm installing Stromberg carbs, selling my Webers Triumph 11
19_again GT6 gt6+ and webers Triumph 8
J TR4/4A TR4 Webers Triumph 5
Jim_Newman Webers Austin Healey 6
DrEntropy 45mm DCOE Webers, anyone? Racing 1
B GT6 GT6 Webers for sale Triumph 5
G Wedge TR7 with twin webers Triumph 1
billspohn There are Webers and then there are DGVs Triumph 18
hondo402000 vacuum advance for triple webers Triumph 2
Darrell_Walker Running with Webers Triumph 5
Darrell_Walker TR4/4A Manifold clamps on TR4A when installing Webers Triumph 11
Darrell_Walker Headers/exhaust manifolds for 4 cyl TR with Webers Triumph 12
B Air Filters for Triple Webers, BT7 Austin Healey 9
JFS Fuel pump for Webers Triumph 19
TR4nut TR4/4A Speaking of Webers - TR4 application question Triumph 38
T fuel pumps for webers Triumph 14
S Triple Strombergs or Triple Webers Triumph 15
L Webers Austin Healey 6
T jetting webers & dellortos Triumph 0
Alan_Myers 42 DCOE Webers Racing 1
philman Wedge swapped to webers on my '76 tr7 fhc Triumph 0
Basil Twin Webers too much Triumph 15
BierRunner TR6 TR6 Trunk Lock Striker Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
