How do I open my tach without breaking stuff?
58Custom
Last time I drove the 1969 Midget the Smiths tach started operating intermittantly. I found that if I pressed on the wires going to it that it would work. I pulled the tach out this evening and noticed that the male bullet terminal seems kinda loose. Does this terminal solder into a PB board or something? I can't tell from the outside. I would like to open the case and take a look at the connections to check for problems but I don't want to turn the wrong screw or mess anything up. Any sage wisdom?
Platinum
It'll be "crimped" to a PC board inside, most likely with a rivet. First step is to TRY turning the chrome bezel to line up its tabs to the cut-outs in the "can". That can be tricky, but patience is helpful. Remove bezel and glass carefully... Then remove the two screws at the back that have lock washers under 'em. This frees the innards so you can access the board. Be careful removing the guts, as the needle can be bent easily. There are a number of good references here on the forum, chief among them are the PDF's Doug Lawson (dklawson) has links to:
https://www.britishcarforum.com/bcforum/ubbthreads.php?ubb=showflat&Number=152595
<span style="font-style: italic">EDIT: And welcome to the forum! You'll find this place to have many folks with great advice. Usually very quickly. </span> :savewave:
jlaird
X axcto knive or some such thin blade under the chrom Bezil all the way around to un stick the rotten seal will help.
Michael Oritt Post- Open Roads 2002: Tahoe to MD the long way Austin Healey 19
Michael Oritt Open Roads International 2002: A Journal Austin Healey 37
60TR3A Driver's Door Won't Stay Open Austin Healey 1
Michael Oritt VRG Turkey Bowl XXI now open for registration Racing 0
bighealeysource Strange problem with throttle staying open Austin Healey 6
S Open a ingnition key barrel to find the key number. Restoration & Tools 2
Popeye Contact adhesive for open cell foam - seat rebuild [TR4A] Restoration & Tools 8
Steve P. Formula Mazda open wheel race car Racing 0
P Doors won't stay open [1959 100-6] Austin Healey 16
J TR2/3/3A How to get the glove box open? Triumph 3
K TR2/3/3A 3A Gas Cap keeps popping open? Triumph 5
J Had a flat on the way to Mini Mania open house Austin Healey 4
BN6_2197 Tool to open/close rain plug of gearbox and rear axle Austin Healey 17
S MGB 5 classy classic cars for the open road MG 2
0 Open hole on Transmission Spridgets 9
A door will not open Triumph 8
MadMarx Memories of the last Nordschleife race with open top cars.... Triumph 4
apbos Austin Healey Museum open in the Netherlands Austin Healey 6
M open discussion on fiberglass tops Spridgets 18
mdionne It appears window has been left open! Spridgets 12
RJS Thermostat Stuck Open? Triumph 11
AH67 How to open hood? Yes i'm serious. Austin Healey 5
T OT - but worth watching if the open road calls Triumph 0
JeffS Open House/Party Triumph 2
JeffS Open House/Party in MN Spridgets 2
J Got the hood open and surprise! Triumph 13
E XK's open house. Jaguar 2
rick_ingram MG 2011 - Website open for registration MG 0
richberman To open or not open the differential..that's the ? Austin Healey 11
6 trunk won't open Triumph 12
aeronca65t Open Practice-NHMS, Lime Rock, NJMP + Pocono Racing 0
walshja 2010 British by the Sea registration is open - Con Spridgets 0
B Loss of compression due to valve stuck open Austin Healey 2
D 2010 6-Pack TRials registration is open! Triumph 1
P Can't get the truck to open Jaguar 29
G An open apology Spridgets 25
G Throttle stuck wide open on the way home tonight Spridgets 14
angelfj1 New laptop can not open BMIHT CD's Triumph 14
B Pic. from today, TR in a open shed. Triumph 29
S Door won't open Triumph 12
longbridgehealey door won't open Austin Healey 4
toysrrus Puerto Rico Golf Open - Weather looks Good! Triumph 13
Freespeech Open for suggestions Triumph 27
YankeeTR A few pix from the FoxBrits Open House Triumph 0
YankeeTR Fox Brits Open House this Saturday Sept. 22nd... Triumph 0
M Throttle stuck wide open Austin Healey 4
Westfield_XI LBC open house this Sunday in Los Angeles Lotus 13
Westfield_XI LBC open house in SoCal July 15 Spridgets 4
YankeeTR Somebody needs to open their wallet for this car.. Triumph 9
A Ebay Warning don't open it! Austin Healey 8
