TR2/3/3A holding the paint gun away
sp53
It is funny to start with intro before I die—I am with you John. Anyways I have been watching and leaning and some guys say they hold the paint gun on average of 12 inches away and others 7 to 8 inches one guy said 6 inches, so I am just curious about others. I guess I think 8 inches works for me.
steve
DavidApp
I probable try to keep it about 8" but that varies as I swing back and forth.
There is a You Tube video on spray technique that suggests you tape a card fan to your gun set to the distance you want to maintain. This is intended to build muscle memory.
At about 10 minutes in he has a brush to do the same thing.
https://www.youtube.com/watch?v=P_9WQmicyJU
David
CJD
I had to think about this for a while. The distance and spray setting are co-dependent. So if you spray closer, you’ll need slightly less paint than when you spray farther. I probably gravitate to 8-12 inches, for no other reason than it feels about right most of the time. Sometimes, like spraying into the spare compartment, under the dash, or under the rear scuttle, you have to spray up to 30” away. For that I adjust the pattern more oval or round and dial up the paint adjustment. I also think when I have to lean way over a bonnet to reach the center, I tend to back out to about 14”, mainly so I don’t drag the hose over the bonnet!?! With thin paint I also tend to move away a bit, as that gives better control to prevent runs. Very thick paint...especially when I got caught with too small of a tip...makes you get closer to keep the spray wet, so it doesn’t dry out enroute to the panel.
So my answer would be to use what’s most confortable for you...and then learn to adjust when you need too?!?
S
sp53
Yes David I like that video. The first time I tried to watch it, I shut it down before it got to some of the good stuff.
M_Pied_Lourd
I think I am pretty much on a par with what John has to say....again, it comes down to "practice makes perfect"....once you get to understand the materials a bit better and the equipment that you are working with it gets easier. You make adjustments as required. I try to be fairly "robotic" in my movements and really concentrate while painting (I even turn my music off!) Still, lots of other variables to contend with as well.....right now I am trying to content with the weather and trying to find a day where the humidity will allow me to spray....Heat and humidity will change the way you spray as well...
Cheers
Tush
Nelson 62 years and holding Spridgets 3
S TR6 1974 TR-6 project....I'm holding my breath and praying Triumph 13
zimmy clutch not holding Spridgets 19
P midget holding back/ carb problem? Spridgets 1
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
D TR6 Valve cover paint Triumph 5
TomMull Paint over galvanized parts? Restoration & Tools 8
Sopwith_Camel MGB-GT lick of paint 1 2 3 MG 2
Rut MGB Pale Primrose touch up paint MG 4
J Paint code Spridgets 0
J 1960 Bugeye Paint Codes Austin Healey 1
J Paint code Austin Healey 4
M Old English White Paint Code for early BE Spridgets 1
J Flaking Paint Inside Differential Austin Healey 6
C Under boot and under bonnet paint? Austin Healey 7
T TR2/3/3A Chassis paint color Triumph 10
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
vette MGB Paint Code MG 8
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
B Engine paint Austin Healey 17
