General Tech Head Gasket
KVH
I'm getting ready to reinstall my cylinder head with a new head gasket. It all seems so familiar. It also seems so simple. Are there any pointers I should remember? I plan to use no gasket sealing material. I have a new gasket from Moss and all looks fine. ARP head bolts, and I will torque spec.
malbaby
Not all gaskets are manufactured correctly......Check that there is no intrusion at all of the edge of the gasket into the combustion chamber.
charleyf
Most head gaskets look like they will fit with either side up or down. My opinion is that the side with the fold exposed should go on the top. I have had two fail over the years because water got into that fold when the fold was on the block side.
Charley
trrdster2000
Coat both sides with cooper head gasket spray. Why take a chance?
Wayne
TomMull
I can't argue with Wayne but if everything is in spec, e.g. liner heights correct, head flat, etc. the Copper gasket spray is probably not needed. However, the only down side I can think of using it is that it might make future head removal a bit more difficult.
Tom
CJD
I've been using the original Wellseal. I was sold when I heard it was developed to hold 3k horsepower in the Mustang Merlin engine! Currently you have to order it from the U.K., though.
martx-5
Is the Wellseal that's available here different than the stuff in the UK?? Pegasus shows it in stock. Not cheap, and there are shipping restrictions and costs. Pretty hazardous stuff it seems. :scared: I have a tube that I used during the resto, and I didn't send away to the UK for it, but that was a few years ago. I don't remember where I got if from.
https://www.pegasusautoracing.com/productselection.asp?Product=3304
RJS
I did my head gasket this summer. Original copper gasket didn't fail. I had a cracked head stud which needed to be replaced - went with ARP head studs.
No coating on old copper gasket and head lifted clean off.
I have 87mm pistons and shaved head with 180psi compression. Went with the Lucas gasket with silicone (touted as last gasket you'll ever need) which handles up to 89mm pistons. I super cleaned head and block deck incl several wipes with acetone.
Installed gasket dry and torqued to 110 lbs-ft (per ARP) in five stages over five days. Retorqued again after first 20 min heat cycle and good as gold.
KVH
KVH
You're saying that after 20 minutes of start up you removed the valve cover and rocker arm assembly and re-torqued? I thought that was only after the first 500 miles? No?
KVH
KVH
Sounds good. But you must be really efficient at tappet adjustments. I slog through that for an hour each time.
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
T TR2/3/3A tr3 head gasket Triumph 38
DrEntropy MGB Head gasket R&R goes on... MG 13
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
R BJ8 Cylinder Head Gasket Austin Healey 38
B TR4/4A Head gasket won't lay flat Triumph 13
Michael Oritt Head gasket question Austin Healey 17
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
Simmo TR2/3/3A Head Gasket Triumph 4
RJS General TR Head Gasket Test Fit Triumph 5
D TR2/3/3A head gasket... which way up?! Triumph 8
KVH TR4/4A Blown Head Gasket? Triumph 12
T TR4/4A Head gasket sealer question Triumph 7
T TR4/4A How to prep block to reinstall head for composite gasket Triumph 3
T TR4/4A Composite vs cooper head gasket with Randall's "trick" Triumph 6
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
H TR4/4A Head Gasket Issue Triumph 4
Got_All_4 TR2/3/3A What direction does the head gasket go? Triumph 4
T TR4/4A Best head gasket for a 4A? Triumph 12
DornTRoriginal TR2/3/3A TR3 Head Gasket Questions Con't Triumph 3
B Victoria British Head Gasket Austin Healey 6
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
G Payen XK engine head gasket -- which side is the top? Jaguar 2
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
S Recommendation on Head Gasket? Austin Healey 14
S Tolerance for head gasket Austin Healey 10
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
Gliderman8 TR6 Question on installing new head gasket Triumph 2
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
B Experience with Cometic Head Gasket for BN2? Austin Healey 8
S SaxMan's Cylinder Head Overhaul / Head Gasket Replacement Thread Spridgets 135
M TR2/3/3A Head gasket leaking in two places Triumph 13
S TR2/3/3A head gasket Triumph 5
AngliaGT General MG MGB GT Head Gasket - What do I need? MG 3
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
O HEALEY 100 Head Gasket Gone ? Austin Healey 10
J Blown head gasket in 3 min. a new record! Triumph 14
