Payen XK engine head gasket -- which side is the top?
Goodfellow
I'm ready to install a new head gasket in my XK engine and ordered a Payen head set. Unfortunately the head gasket isn't marked as to "top" or "bottom". There is a difference in the two sides of the gasket
One side has a metal reinforcement on the rear water passages, while the other side does not.
This is the side without reinforced rear water passage
This is the side with reinforced rear water passage
Also, notice that the metal cylinder sealing rings in the gasket are wider and more pronounced on one side than the other
I called the seller and they said that it doesn't matter which side is top or bottom -- not sure I believe that story.
LarryK
I have never used this gasket for an XK engine. Cannot say for sure. Just Googled and got copper down.
G
Goodfellow
E-mailed Payen in Australia and they were very helpful. Apparently there is a top and bottom side to these gaskets. The side with the wider fire ring and the metal reinforced water passages are the "bottom" of the gasket.
J Spitfire Payen Head Gasket -which way up ? Triumph 6
DrEntropy MGB What th' heck happened to Payen?!? MG 17
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
Michael Oritt Payen head gasket question Racing 5
64rocksprite Payen head gasket...mislabeled? Spridgets 3
KVH Payen Head Gaskets Triumph 4
Morris Payen Head Gasket Spridgets 18
C Payen Head Gasket Austin Healey 6
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
