pkmh
Hello Community!
Finally we have nice weather here today, so I decided to become more familiar with my HD8 SU Carburetors (proceeding with caution, mind you) by attempting to remove them for rebuilding purposes and while at it, gain easier access in repairing or replacing both clutch and brake master cylinders below it.
I almost was completely successful in removing all securing carburetor rear body mounting bolts to the intake (except one, of course), the one positioned below and forward on the rear SU. I experimented in removing the slip linkage between the two SU's so as to remove one carburetor (front) first, but there must be something else I am required to do in order to successfully remove the entire linkage, maybe?
I was hopeful in removing the sixth bolt so I can remove the SU's in its entirety. Does that sound like the right way to go?
If so, should I then be looking for a special tool for that hard to get to place or is there an easier way (ie.- understanding removing slip linkage)? I have no material so far on dismantling but if I could get past this hurdle, I should be in good shape to proceed.
And thoughts on this?
Thanks,
Paul
Thanks,
Paul
