HD8 high idle aggravation
steveg
My HD8s have had this problem in the several years I've had them: idle was originally set to around 800 rpm. Driving the car, coming to a stop the idle is around 1500; then sitting at a stoplight, it will gradually settle to approximately 1000. I can blip the throttle and it'll slow to 800. The carbs are relatively new, having been rebuilt when I bought them a few years ago. Distributor rebuilt by Jeff at Advanced a few years ago.
No visible binding in the linkage.
Would appreciate ideas on what might cause this.
DerekJ
I'm pretty sure it does have something to do with the linkage and not the functioning of the carbs themselves. I had exactly the same problems with HD6s on my original 100-Six. I never did manage to eradicate it.
rjc157
It has to be in the linkage somewhere something might be slightly off ,it also could be a vacuum leak
bob hughes
How about trying some stiffer return springs to substantiate the linkage theory?
My HS6s are a bit iffy but I am putting it down to the fact that they have never been rebuilt and I know that there is a slightly dodgy joint on at least one of the carbs.
:cheers:
Bob
RAC68
Hi All,
Over the years, I can't even estimate how many times I tried adjusting the carburetors, set the linkage or even rebuilt each unit in my attempt to gain a steady idle under 900-1000 RPMs. However, since so many HD8/BJ8 owners have indicated similar experiences to my own, I tend to believe the issue is in the carburetors, intake manifold/head design, or something else inherent in the Healey's engine that can NOT be corrected by carburetor adjustment or linkage realignment.
I appreciate that Healey models previous to the BJ8 seem to be able to achieve a steady 600 RPM idle and the only obvious differences I am aware of are that they do not use HD8s and have lower compression ratios. Are there any other model differences that would cause a BJ8/HD8 to require a higher idle speed from its predecessor?
Ray (64BJ8P1)
steveg
steveg
My engine is a fairly tired 29D with high-lift rockers, a DMD manifold and Kirk headers. No internal mods. Didn't have this problem when running the HD6s.
After all this, it seems like the problem is in the carbs. Eric Grunden said he thinks the castings can change shape slightly when hot, causing the butterfly shaft to hang up.
Keoke
I agree with Ray,
if you check your idle speed indicated on the car tach against an accurate hand held unit you will generally see 1ooo RPM on the car tach is equal to about 600 to 700 RPM on an accurate instrument.
DerekJ
Ray, I would have to disagree with that. The problem being described is car specific. There are thousands of people with HD8s that have no problem with the revs 'hanging up' until the throttle is blipped. I had HD8s on my current 100-Six, with a DWR cable throttle set up and never had any problems at all. I did have the problem on a previous car with HD6s, then no problems at all with a second car with HD6s.
It is probably caused by a combination of mechanical issues, the most likely is the crazy throttle linkage system that is difficult to get exactly right, particularly as part of it is virtually inaccessible and so never gets adjusted. Problems with the butterfly shaft as mentioned above might also be a cause. Stronger springs would be worth trying as a first step.
RAC68
Derek,
I may have confused everything. The throttle hang-up is, I believe, a mechanical issue with either the linkage or carburetor throttle plates hanging up. The issue I was focused on was what I believe is the inherent high idle reading of the HD8/BJ8 that is not caused by a sticky throttle.
Although I agree with your assessment for the most part, another issue I have experienced that has caused high irregular idle speeds requiring a blip of the throttle is a sticky choke. My BJ8 came through with 1 chock spring hooked to frame and attached to a "Y" piece of wire that pulled down on the choke levers. Although this seemed to work rather well, it required a strong pull of the choke for actuation and, over years, became inefficient in pulling off both chokes. As a result, one choke was left slightly on (usually the rear) leaving that HD8 running a little rich.
To address this choke release issue, I followed a friend's advice and purchased 2 springs that I installed on the actuation cable of each choke to push the lever to the closed position. Although this did solve the issue, it make pulling the choke even harder when reaching through the steering wheel so I returned to the single spring and "Y" wire with the occasional requirement to get out of the car and push the rear choke home by hand. Although it would be nice to find a correction for this issue, I have put up with it for more then 50 years and expect will continue.
Ray (64BJ8P1)
steveg
steveg
My throttle issues do not involve the chokes. I fixed that by replacing the cable housings with teflon-lined bicycle cable housing and used setscrews at both ends to secure the housing from moving. See: https://www.pbase.com/stevegerow/image/109638552
I suppose it's possible the linkage is involved but have never seen any indication. With the carbs off the car, the butterflies seem to seat properly every time.
My feeling is my particular problem is internal to the carburetor.
Possibly the next step would be to remove the carbs and heat them in a 175 degree oven to see if anything changes in the operation of the butterfly. Way too much trouble.
why
how about just squirting every possible place in linkage with a WD-40 like product cause its so easy to do and who knows, maybe?
TimK
Just wanted to say I've lived with this on my HD6's for 34 years. I'd like to learn of a solution.
M New Member with an HD8 Carb Question Austin Healey 1
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
G HD8 Carb Leak Austin Healey 7
G HD8 Carb Banjo Bolts Austin Healey 2
G HD8 Idle Adjust Screw Austin Healey 10
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
O HD8 carb on Healey 3000 Austin Healey 62
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
ArchieMcAllister Wanted Rebuildable set of HD8's Austin Healey Classifieds 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
J Wanted HD8 SU carb set Austin Healey Classifieds 6
wangdango Colortune for HD8 Carbs? Austin Healey 55
B mysterious leaking of SU HD8 Jaguar 9
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
vette Adjusting HD8 Carbs Austin Healey 21
D S.U. HD8 Carburetor Drawing Austin Healey 6
S Float valves for HD8 - Grose Type Austin Healey 20
AUSMHLY HD8 pin & spring assembly Austin Healey 6
Jeepster HD8 carb float bowls Austin Healey 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
tinman58 TR3 with a Jag HD8 carb SuperCharged Jaguar 10
tinman58 HD8 S/C carb ? Triumph 9
C Hd8 su fuel lines Austin Healey 2
D Rebuilding the SU HD8 carbs Austin Healey 24
pkmh HD8 SU Carburetor removal Austin Healey 48
D HD8'S Austin Healey 3
D HD8'S Austin Healey 4
W Rebuild recommendations for HD8 Austin Healey 5
AH_3000 Guys...What is this on a HD8??? Austin Healey 8
S Float Level for HD8, BJ8 carbs Austin Healey 9
macey75 Set of 2 new SU HD8 carburetors, Healey 3000 mk3 Austin Healey 0
D HD8 Carb. Value Austin Healey 7
D K&N filters for HD8 carbs Austin Healey 26
J HD8 carb float adjustment. Austin Healey 1
B HD8 SU carb suction chamber. Jaguar 0
F HD8 Carb Set Up and Adjustment Austin Healey 2
BOBBYR HD8 Carbs Austin Healey 2
AUSMHLY SU HD8 carb set Austin Healey 6
Ed_K What are the correct damper p/ns for HD8 carbs? Austin Healey 2
M Air cleaner for HD8 on BJ8 Austin Healey 5
R Help - Need SU HD8 Part [Throttle Lever] *DELETED* *DELETED* Jaguar 1
R Help! - Need SU HD8 Part [Throttle Lever] Austin Healey 5
Lin HD8 carb dashpot height Austin Healey 1
David_K Question about SU HD8 carb gasket kits Austin Healey 5
A BJ8 SU HD8 carbs for sale Austin Healey 0
J HD8 shaft bushing & king pins. Austin Healey 6
R Setting up HD8 carburetors Austin Healey 6
Lin HD8 carbs Austin Healey 2
